I am having some issues with a 180 sd. D/C works fine A/C not so well. The arc will spit and sputter about 3 times before it blows a hole through the aluminum, I had both scrs tested they are about 1 ohm apart from each other looking for some suggestions on what might be wrong thanks.
Please help A/C trouble
I'm sputtering too
Hey guys just joined up ... Hope you don't mind that join in on this thread but my 180SD is doing the same thing, sputters and I can't keep the arc from wandering. I bought mine used from a farmer in pa, works real well on EN and EP but the AC is killing me... 3/32 aluminum brushed clean, 3/32 green tipped tungsten argon flow at 20-25 garage door closed and all I get is spatter can't get it to puddle to save my lifetried 5,6,8,and 10 cups all yield same result.
i read manual, checked all the settings and tried all sorts of combinations and nothing makes it better?
My SN is LF119554 stock no is 907054
im a total rookie but did take the basic and advanced welding course at community college ... Can't get my teachers on the phone... I have a chance to make a few bucks repairing some welds on a buddies quad footrests but I'm dying here any guidance would be appreciated.
Originally posted by Jorge View Postthe AC is killing me... 3/32 aluminum brushed clean, 3/32 green tipped tungsten argon flow at 20-25 garage door closed and all I get is spatter can't get it to puddle to save my life
Try the brown ones first before looking at the machine.
Green will work in a pinch but they're not as good as brown.
Look for the word "Zirconiated" on the package.
Originally posted by Matrix View PostOne possibility is that you may have a contaminated electrode.
i did not sharpen electrodes on two tries to rule out contamination, then I tried sharpening the 3/32 and I'm still the same. I am lighting up on fairly crappy pieces do scrap... But nothing too thick and its not really that dirty - I think I should be able to move around on a piece and get a puddle going at some pointLast edited by Jorge; 10-18-2012, 04:19 PM.
Originally posted by Matrix View PostNot ceriated, I said zirconiated.
Not brown/orange, I said brown.Gotcha... Just wanted to throw that intel out there in the event someone had feedback about my efforts... Gts-welco is getting a visit in the am for the zirc tungsten blend that I don't have here... I will report back in the am...
feeling confident its the man not the machine or al least the component mix not the man so much...
It's long been my observation that about 80% of welding problems are caused by operator error and only about 20% are caused by machine malfunction.
Noob to TIG
I've welded before, but only MIG & stick. Not a lot of experience but I can get by. I had issues such as described here. Fortunately I have a friend if mine who came over & helped me work through it. I bought my 180 from a guy who had it sitting up for a number of years in his wood shop. I took the torch a parts & cleaned it thoroughly. Only problem was I reassembled it like a moron by not reading up. I also didn't clean the inside of the cup either. Once that was all cleaned, reassembled properly & the ground buffed clean, everything worked just fine both AC & DC. Also a new electrode that's ground properly I've found helps a lot too!
Originally posted by mattcreswell View PostI've welded before, but only MIG & stick. Not a lot of experience but I can get by. I had issues such as described here. Fortunately I have a friend if mine who came over & helped me work through it. I bought my 180 from a guy who had it sitting up for a number of years in his wood shop. I took the torch a parts & cleaned it thoroughly. Only problem was I reassembled it like a moron by not reading up. I also didn't clean the inside of the cup either. Once that was all cleaned, reassembled properly & the ground buffed clean, everything worked just fine both AC & DC. Also a new electrode that's ground properly I've found helps a lot too!
trying to upload a pic because everyone likes to see pictures
Here is my test piece
Photo upload test... This is one of my test pieces... It was getting bad towards the end...Attached Files
Not to be a constant nitpicker but it's zirconium, not zinc. Like cubic zirconium, the stuff fake diamonds are made of.
Still ..... That pic looks awful. Are you sure it's even aluminium?
That looks like a more multifaceted problem than just the wrong tungsten.
Although starting with the right tungsten is always the best way to start.
Where is your balance control set?
What kind of amperage are you running?
And the spatter all gathering together in clumps, I don't quite get that.
The first thing that comes to mind is you might need to set your balance for more cleaning (EP) and less wetting (EN). I think of that because of the yellowish oxide but even then it's still confusing because the oxide is outside the weld area.
You may also want to decrease your argon flow to 15 CFH and go back to using one of the larger cup sizes you have been trying. You could be drawing air into the shield gas by having it flow too fast.
Let us know how you make out.Last edited by Matrix; 10-18-2012, 10:47 PM.
Other things to double check:
You said you cleaned the aluminium with a wire brush but is there any chance the surface could have some grease or oil on it or some other chemicals?
Which filler rod are you using? There's lots of filler rods but the two main ones are 4043 and 5356. Chances are good you're using one of those. Prolly 4043. Whichever one it is, you might try the other. You could also try some 4047.
What kind of arc length are you holding? You could tighten it up a little just by looking at your pic. It's easier to contaminate your electrode by holding a tighter arc but I think you may need to anyway.
