Trailblazer Cover Needed?
  • Trailblazer Cover Needed?
    I've got my TB302 mounted in the back of my truck. It doesn't get covered parking.
    Is the welder going to be ok when it starts raining? Or do I need to cover it to keep water off?
    Thanks.
    Lincoln Vantage 400
    Trailblazer® 302 Air Pak™
    Miller Dynasty® 350
    Millermatic 350P Aluminum
    Millermatic® 252
    Syncrowave 351
    Lincoln LN-25 Pro
    Multimatic™ 200
    XR-Aluma Pro Gun
    Diversion™ 180
    Spectrum® 625 X-TREME™
    Thermal Dynamics® Cutmaster® 52
    Victor Oxy/Acetylene Set
    I'd say yes but that's just me. I see you're from Tracy. I'm from Stockton.
      Mine has been truck nounted for the last four years,and never had a problem. The only time i cover it is during,and after snowstorms. The amount of salt that is used on the roads is what concerns me.
        $375 + Shpping full working cover, ie, you don't have to remove it to use the welder.
          cover
          Can you send me a pic.of one that's sounds like what I have been looking for
          ARMOR
          MOBILE WELDING&SERVICES
          Trailblazer 302
          X-TREME 12VS
          Spoolmatic 30A
          Millermatic 135
          WeldCraft WPseries TIG torch
          Smith oxy set.
            Nice. I'll look for that one.
            I did email Miller and they said the Trailblazer is designed to withstand the weather. But I'll get one anyway just to keep'er looking new.
            Lincoln Vantage 400
            Miller Dynasty® 350
            Millermatic® 252
            Syncrowave 351
            Lincoln LN-25 Pro
            Multimatic™ 200
            XR-Aluma Pro Gun
            Diversion™ 180
              I'll need a TB to stick it on, though they go out just as fast as they come in.
                TB Cover
                Cruizer, please post a photo of the cover. I might want one.
                  not trying to steal anybodys thunder....
                  http://www.millerwelds.com/resources...t=welder+cover
                  Check out the #18 posting, some pics of the covers , Best to check with the man to see if anything has changed on them, They are the cats meow!
                  P.S. Cruizer is the man!
                  I have a welding addiction
                  ...the only stupid question is the one you didn't ask
                    The exhaust cut out was kinda squrrelly, thats been changed
                      Is there one specifically with the air-pak cut out?
                      Lincoln Vantage 400
                      Miller Dynasty® 350
                      Millermatic® 252
                      Syncrowave 351
                      Lincoln LN-25 Pro
                      Multimatic™ 200
                      XR-Aluma Pro Gun
                      Diversion™ 180
                        Can not run this horse with any cover
                        Is there one specifically with the air-pak cut out?[/QUOTE]
                        When not in use and cool, cover it.
                        Miller sells a cover for $140.
                        Just Jim
                          There is just not enough airpacks around to justify making a cover for one, as for Miller covers, giver. You have to remove it when the machine is in use, and its not insulated. At -30 thats all I want to do is get up on my rig and remove the snow, remove the now hard Miller cover, then hope to heck that it starts. End of shft, brush the snow snd moisture off the machine, and close it up with that cover. And hope that it doesn't freeze to the machine for the next day.
                          With a 50 wt pan heater under the engine (on a TB, and other) plus an insulated cover, that engine and generator is warm. Open the front flap and start it up. Weld away, end of shift, close the front flap, go home.
                            love to run one about 27-28 volts all day
