Just got a qoute on some steel post I want for a barn. Steel would be around 2000 and the labor 10,000. Good excuse to finally buy a welder. So this would probably by the biggest job I would ever need a welder for. It would consist of 8 post of 5X5 3/8 HSS tubing with a 3/4" base plate. I would also like the ability to weld alumium and stainless steel. What would your recomendation be.
New need a welder
Just don't buy a 110v machine.Lincoln Vantage 400
Trailblazer® 302 Air Pak™
Miller Dynasty® 350
Millermatic 350P Aluminum
Millermatic® 252
Syncrowave 351
Lincoln LN-25 Pro
Multimatic™ 200
XR-Aluma Pro Gun
Diversion™ 180
Spectrum® 625 X-TREME™
Thermal Dynamics® Cutmaster® 52
Victor Oxy/Acetylene Set
I think the machine I have is perfect for that job. It's the 211 Autoset.
http://www.millerwelds.com/products/...p?model=M00245
With a self shielded wire you'd be fine building your structure outdoors. Once you had the building up and you could get indoors you can set up the machine for both aluminium and stainless. Aluminum would require an optional gun and both would require a shield gas, so put up your buliding first. The machine requires 25A @ 220V using a 6-50 connection. It will run on 110 but not nearly as well.
3/8" is max for the MM211 and would probably stress the little machine on the Barn project as well as hitting duty cycle quickly.
best bang for the $ is the Hobart Ironman 230
$2000.00 includes shipping and 20' Spool gun
http://www.northerntool.com/shop/too...=%7Bkeyword%7DEd Conley
MM252
MM211
Passport Plus w/Spool Gun
TA185
Miller 125c Plasma 120v
O/A set
SO 2020 Bender
You can call me Bacchus
on the Barn project you'll hit the duty cycle way too soon.
Look at the Hobart Ironman 230 with spoolgun at Northern Tool.
I'd include a link but the post gets delayed because of the linkEd Conley
MM252
MM211
TA185
O/A set
SO 2020 Bender
The HSS is 3/8".
That means a 3/8" fillet to the 3/4" plate if I am reading that correctly.
And either 3/8" fillets or grooves between HSS pieces.
There won't be any 3/4" welds.
Not that I even believe in those thickness ratings anyway.
Steel is steel. If you need more weld you run more passes.
The only rating that matters is amperage and duty cycle.
Thickness is irrelevant.
The OP says this is the biggest task by far that he'll ever use it for and since he needed an excuse to buy a welder I think it's safe to say this building is not a paying job so it won't be go-go-go-go-go! Rather something he will do in spare time. The duty cycle will likely be fine too as long as he runs it on 220, uses small wire and doesn't treat the task as thought he's being paid by the inch.
I've built bigger stuff with smaller equipment and it's still standing. The 211 is plenty big enough.
Ok so I think there is a lot more to this than the op suggests. 8 posts of 5x5 tube with 3/4" base plates & the labor is $10 grand? Something doesn't sound right.MM250
Trailblazer 250g
22a feeder
Lincoln ac/dc 225
MM200 black face
Lown 1/8x 36" power roller
Arco roto-phase model M
Vectrax 7x12 band saw
Miller spectrum 875
30a spoolgun w/wc-24
RCCS-14
Originally posted by MMW View PostOk so I think there is a lot more to this than the op suggests. 8 posts of 5x5 tube with 3/4" base plates & the labor is $10 grand? Something doesn't sound right.
I dunno..... who knows? He doesn't appear to be coming back to monitor his thread.
"Not that I even believe in those thickness ratings anyway.
Thickness is irrelevant."
Spoken like a true idiot! Be sure to let all the pro welders know that they didn't need to spend 10-20K n their machines to build all those bridges/pipelines/skyscrapers/etc, a little MM211 would work just fine, just run more passes.
Spoken like a true idiot! Be sure to let all the pro welders know that they didn't need to spend 10-20K n their machines to build all those bridges/pipelines/skyscrapers/etc, a little MM211 would work just fine, just run more passes.[/QUOTE]
Bit strong, but yes multi pass are no substitution for volts that you need for penetration,Last edited by go2building; 10-06-2012, 07:48 PM.
My vote is a engine drive rental you can rent a diesel drive machine for $250 a week I would get everything layed out and ready rent it burn it together and take it back. Even at a month for $650 you are still ahead of the game. If your biggest project is going tobe this you can still have get the rental and then buy your self a small mig welder. I would must rather be draging leads around then carrying a 60 pound mig welder with a small duty cycle.Lincoln Vantage Kubota diesel 30 amp spool gun , Hobart 210 with spool gun, Thermal dynamic pak master 75, miller 304xmt all mobile all ready to go.
