I have a syncrowave 351 in my garage, and every time I click the amp. pedal and the high freq start turns on, the GFCI outlets immediately trip off. The outlets are each fed from one leg of 110 that the welder is connected to. The GFCI outlets use the common as the neutral, and are grounded to the breaker box. The welder just uses the two 110 legs, and is grounded to the box - it is not connected to the common. What can I do to prevent the GFCI from tripping?
Thanks
Thanks
