have a 2012 bobcat 250 EFI and need to put a MIG aluminum spool gun into the equation for a project upcoming in the field. What do I need to make this setup work? I was told I needed to get a new Trailblazer instead from my local welding shop. Any way I can use an adapter to make work? Thanks!
aluminum spool gun and bobcat 250EFI?
Those would be the correct items. You will need a chunk of weld cable to go from the Bobcat to the WC-115, for a work cable you can use your work cable that goes with your stick cables and of course you will need argon gas, aluminum welding wire and I would suggest some extra contact tips as well.Kevin Schuh
Service Technician
Miller Electric Mfg. Co.
Originally posted by Miller Kevin View PostThose would be the correct items. You will need a chunk of weld cable to go from the Bobcat to the WC-115, for a work cable you can use your work cable that goes with your stick cables and of course you will need argon gas, aluminum welding wire and I would suggest some extra contact tips as well.
the two machines Bobcat vs Trailblazer, I have welded
extensively with the Trailblazer and a 30A spoolgun, but not with
the Bobcat..Trailblzer runs great even with a Promax gun....just wondering....PaulMore Spark Today Pleasesigpic
