I recently installed the Smith argon flowmeter regulator that comes standard with my Millermatic 175. Because I had been using my old CO2 set-up, I had my old regulator with its questionable gauges. My Miller distributor gave me an adaptor that allows me to hook up the argon regulator to my CO2 bottle. (Yes, I will be converting over to argon mixtures soon anyway.) Here's the question. I am very familiar with the low and high pressure gauge set-ups on systems such as oxy-acetylene. But I am fairly new to using flowmeters on the low pressure side. I never had anything weird happen with the old gauges, but then again, I said they were questionable. After installing the new Smith regulator, it took quite a while before I could adjust it so that I could get 20-30 CFH while welding. When I stop welding, the gauge rises until the needle tops out against the bottom of the "bottoming-out" pin. I had to screw in the adjusting screw A LOT before I could even get it to maintain the 20-30 CFH while welding, even having to remove some kind of a built-in stop built into the adjusting screw. Is any of this normal?
GMAW flowmeter regulator
No this is not normal!!
Bring the regulator back to your distributor and have him get you a new one under warranty.
There was a bad batch of regulators that Smith gave us. Sounds like you got one.
Normally the gauge will fall a little while welding, but only about 2-5 cfh. If your needle is pegging, the high pressure side is bleeding into the low side.
Andy
new regulator now not flowing
Seems we have a regulator crisis at Miller. What with my first post and another user having another type of problem, I'm now less hesitant to bring this up. The new regulator that I got from my distributor worked great!! - For one day. The next day, it will flow no gas, zero, nadda, zip, regardless of the settings. I once again had to put my old set-up back on the machine to get back to work. Any ideas? Or just keep replacing them under warranty?
Mac,
It sounds like all the bad units may not have been purged from stock. I also had a few bad ones the last couple of months. The vendor was suppose to have fixed the problem. The last batch I got were fine. All I can say is sorry and try again. If it turns out bad again, I'll get a number for you to call to give someone a piece of your mind!
A
