In my line of work (petro-chemical industry) weld procedures are always given to you before you start to weld. You are told which process and which filler to use and you are given only a very small range of options for choosing how you will do your welding. You don't weld outside of the parameters set forth in the procedure. Failure to comply is grounds for dismissal. Flux core is frowned upon and rarely used. Even when it is used I do not choose my own fillers ... so now that I have recently bought myself a small wire feeder I find I don't know what wire to buy. The machine (211 Autoset) came with a 2 lb. roll of solid wire but I am not interested in the hassle of setting up a bottle every time so I want to use flux core. Obviously I do not mean a dual-shield process wire as that will still require a bottle. I went to Peavy Mart and Crappy Tire and the only self shielding wire I could find at either place is E-71T-11. I bought a little 2 lb spool because I only wanted to try it and see how it runs before I spend money on a larger spool.
My question is this:
Does this wire produce a weld with the same mechanical and chemical properties as E7018-H4 (A1)? Is there some other wire that is more appropriate to my needs? I want a wire that is good for dynamic loads. Strong, ductile. Charpy impacts should be the same or better than 7018.
