200DX no high frequency start
  • 200DX no high frequency start
    I have searched and searched.
    I did check the contacts cleaned and set at .010
    I did blow the machine back out and clean out the dirt dauber nest in the bottom. It will weld on lift and stick.
    Where do I check the input voltage to the HF transformer? it looks like the transformer is behind the HF contacts. The machine is an 2005 model, this is the first time I have had any HF problems, actually this has been the first problem I have ever had out of the machine.
    Where do yall check to see if the pedal is triggering for the HF I had seen that some people had some HF issues over the pedal. My pedal did try to commit suicide off the cart a few weeks back but was saved at the last second by the cord.
    Trying to weld up some band saw blades with no HF is proving to be next to impossible.
    Thanks!!!!!!!!!
    DYNASTY 200DX
    SPECTRUM 625
    MM 251
    BWE
    The pedal cord would be the first thing to check since you had that incident. I have had many with broken wires in the cord.
    You could disconnect the pedal and try lift start to see if it works then. Of course you could try another pedal if you have one.
    Miller Dynasty700DX
    3 ea. Miller Dynasty350DX
    Miller Dynasty200DX
    ThermalArc 400 GTSW
    MillerMatic350P
    MillerMatic200 with spoolgun
    MKCobraMig260
    Lincoln SP-170T
    Linde UCC305 (sold 2011)
    Hypertherm 1250
    Hypertherm 800
    PlasmaCam CNC cutter
    Fadal Toolroom CNC Mill
    SiberHegner CNC Mill
    2 ea. Bridgeport
    LeBlond 15" Lathe
    Haberle 18" Cold Saw
    Doringer 14" Cold Saw
      do yall have a wiring diagram for the pedal?
      I'm going to go grab my neighbor's pedal and try it. Hopefully that is it. Should be an easy fix there
      DYNASTY 200DX
      SPECTRUM 625
      MM 251
      BWE
        well I found my finger control. Tried it still no HF, tried AC and DC. No HF and NO HF sounds at all. Where do you check to see if your getting power to the HF board?
        Thanks!!
        DYNASTY 200DX
        SPECTRUM 625
        MM 251
        BWE
          .....anybody up yet??
          DYNASTY 200DX
          SPECTRUM 625
          MM 251
          BWE
            Well it went to the service center yesterday hopefully its not the
            DYNASTY 200DX
            SPECTRUM 625
            MM 251
            BWE
              Just a problem with your HF start board, not a big deal nor is it expensive.
                The shop just called me. One bad IGBT $350 and One bad board $75. $130 labor They said the HF works its just the other problems causing it not to work. They said that is why I was having so much of a problem trying to lift arc what I was welding also with the bad IGBT the current was real hard to maintain. It is the bottom snubber board. Also the one I found the dirt dauber nest on. Hmm I think they may have killed my machine. FM
                One hand I think about trying to get the parts, and matching up the IGBT since I have found 200A 1200VDC IGBT's for $200
                DYNASTY 200DX
                SPECTRUM 625
                MM 251
                BWE
                  Get it fixed for that quote.
                  I kinda think there is more to this especially when they install the new parts, and no you won't find that specific pre regulator inverter module anywhere.
                    That ain't cheap, wow
                      Actually that is inexpensive for this unit, the problem is that the preregulator (IGBT) usually takes out the parent interconnect board which is rather expensive as is the snubber board.
                        I am going to have them fix it since they are going to warranty it also. I am going to get the old parts back. We have a board rework team here at work, and with there help I want to find out what failed and repair the board. On the IGBT once I can find out what the specs are on it they are not hard to find a match. I highly doubt Miller makes the IGBT's and they are all just a voltage and amperage spec component also. I have some IGBT's sitting on my desk that are 10KV 200A there huge. But a 200A 600V IGBT should run about $200
                        I just hope there right on it is only the components they quoted and the machine will be back up the way it should be for the agreed amount.
                        DYNASTY 200DX
                        SPECTRUM 625
                        MM 251
                        BWE
                          i suppose you could find one, its made by SemiKron, its a 1phase rectifier with a 3 phase bridge inverter using trench igbts. Not something thats regularly on the shelf
                            Have you seen a part number on them? I was going to call my rep at allied electronics and see if they have the exact one. I talked to him earlier and they have some trench structured IGBT's on hand I just don't know the full specs. I am worried if this one has failed when is the other on going to fail. Especially with it being the final output all the load stick welding has been put on the one. Which I have been stick welding a bunch lately building fence. I have burned like 25lbs of rod since I had tigged the last time with that machine.
                            DYNASTY 200DX
                            SPECTRUM 625
                            MM 251
                            BWE
                              AS I said, that Module generally takes out the mother interconnect board, and is protected from voltage spikes from the snubber board. Replacing one doesn't really help you. And your best bet is to leave it to the pros. The Miller CST techs are heavily trained for this reason.
