millermatic 130 feed problems wire feeds at 0 on control
  • millermatic 130 feed problems wire feeds at 0 on control
    millermatic 130 wire feed problems wire feeds at 0 on control . should the wire feed out when pot is at 0? . pot still controls speed but it seems to be too fast,
    also welder does not penetrate very well even with setting on highest
    And what are you trying to penetrate?...Bob
      1/4 in steel
        1/4 in steel
        That could be one problem. I never was a fan of 110v welders on thicker metals, sorry. How is it on sheetmetal?...Bob
          does pretty good on sheetmetal do you know if wire should feed at 0 i do not think it did when i first got it
            No zero is a problem...Bob
              is there any certain component that controls the feed on the circuit board.
              board is #119539
                The wire drive motor in the Millermatic 130 runs right off the weld output, the little board does not control the speed. If the unit has the proper weld output and the rheostat is good but the wire runs to fast the only thing it could be is the drive motor itself.
                Kevin Schuh
                Service Technician
                Miller Electric Mfg. Co.
                  The 130 is a good 023 and pushing the limits on 030" wire size machine. 035 will be pretty much a rope looking weld with very little penatration.
                  Yes it runs on arc voltage so unless you have the machines voltage turned to the lowest setting, the rollers will still move.
                    running 035 on it now. will try some smaller wire
                    thanks
                      put 023 wire on it and it runs great thanks for the help
