help me understand this BS symbol.
  • help me understand this BS symbol.
    This is a British Standard symbol. I know its a plug weld. But where?
    Performance Aluminum Fabrication
    is it a sopot or projection weld?
    Looks like a spot weld or a projection weld, might be mistaken though
    I have a welding addiction
    ...the only stupid question is the one you didn't ask
      That would be in the only hole there seems to be
      The rest is a mechanical drawing of the part and has no other holes and only one welding symbol and i think it is on your side of the arrow
      but there are no references as to what the notations in the tail mean
      Backed my CATMA over your CARMA
      OOP"S clumsy me
      What would SATAN do ??
      Miller Digital Elite (new)
      Jackson EQC master (old)
      Miller Trail Blazer 302 Air Pak
      Spectrum 625 Extreme
      Suitcase 12RC
      Evolution Rage 3 saw
      Craftsmen Atlas 12X36 Lathe
      Half a ton of tooling
      Rusty old truck
        bs weld symbol,
        I think the 8x refers to the spot welds , 8 in total, the 4x refers to 4 welds per side of the unit , as it it kinda a laminated sandwich, 4 welds topside 4 welds on the bottom. this details the 8 total welds req'd
          That's how I read it...
          That's how I read it...but what is with the dashed line on top? Is that a bad way of saying stitch weld far side?
          MillerMatic 211 Auto-set w/MVP
          Just For Home Projects.
            I got that part. Im thrown off by the arrow pointed at the center. I think its a plug weld on the near side of the arrow. like this?
            I would think it would call for something like this.
              weld symbol
              If the symbol is on the solid line it means near side. If it is on the dashed line it means far side. The circular symbol can meam plug weld or projection weld.
                AGAIN...IT IS NOT A PLUG WELD!!! There is no hole to "plug." It is a SPOT weld at the crosshair/tip of the arrow...
                  Thats what I thought. so my last post/pictures were correct?
                  whats with the SCREAMING. I think your wrong. A spot weld at the tip of the arrow would not even join the pieces together.
                    It is plug weld cross hatch lines designate hole or it wouldnt be centered FS is far side NS is near side and as for the broken lines on top of the arrow its probably to designate the holes inside the piece most likely a poor detailer did this becuase there is no need for the hidden lines if it was a stitch weld it would have pitch and length desingnated such as 1inch on 3 inch center.
                    The whole problem with the world is that fools and fanatics are always so certain of themselves, and wiser people so full of doubts
                      A weld symbol for a spot weld shows the circle thru the line, a plug weld is actually shown as a box on the reference line but this weld symbol on the drawing is for a projection weld. I looked it up on the AWS chart of weld symbols.
                      The intermittent line is incorrect and maybe its possible the engineer meant a solid line which would mean grind flush. Bob.
                      And if this aint right, maybe ask Drpipe.
                        correction
                        doughboyracer is correct, the symbol means spot or projection weld I typed it in wrong. see link
                        http://www.bing.com/images/search?q=...E8652503F09971
                        I stand by the meaning off the dashed line see link
                        http://www.bing.com/images/search?q=...D9626A&first=1
                        whoever looked this up on the AWS chart, these are not American welding symbols they are European. I also agree that in this instance it would have to be a projection weld.
                          Your right. problem is a spot or projection weld there will do nothing. I shouldn't have let this throw me off. Just like 90% of the prints sent to me this one is full of errors. Im gonna give them a call. Thanks
                            Why wouldn't it do anything? the piece in the middle is 10mm plate with rounded corners and a hole in the middle. Don't see the issue...?
                              i'll help
                              here.... it may be gas or it may be flour, i'll throw it on the fire anyway
                              http://www.roymech.co.uk/Useful_Tables/Drawing/Weld.html
