Originally posted by beamwalker
View Post
Arc Quality - Pro 300 vs Trailblazer
Cruizer, I have to agree with you, When I can buy 3 trailblazers for the cost of one big diesel I cant justify the $12,000.00 diesel.
I also cant justify the Trail blazer air pac, I can buy 2 gas powered compressors for the upcharge of the air option on the welders and the gas compressor is 2 stage and gives me 175 psi that is helpfull when trying to break some bolts loose.
Originally posted by walker View PostMy TB 251 says 50 hr oil change right on the info tag. It is also very good on CV, I wonder what might make your not good on CV?
Originally posted by beamwalker View PostOriginally posted by walker View PostMy TB 251 says 50 hr oil change right on the info tag. It is also very good on CV, I wonder what might make your not good on CV?
Originally posted by Portable Welder View PostCruizer, I have to agree with you, When I can buy 3 trailblazers for the cost of one big diesel I cant justify the $12,000.00 diesel.
and i work out of either of my two pickups and don't have room for a separate compressor that just burns more gas
I don't know when folks will ever learn that higher pressure does NOT equal volume
I have run all sizes of impact wrenches and plasma cutters and sand blasters off the screw compressor and never lacked for full volume at 90 to 100 psi
But i don't run things above there rated pressure it just kills them soonerBacked my CATMA over your CARMA
OOP"S clumsy me
What would SATAN do ??
Miller Digital Elite (new)
Jackson EQC master (old)
Miller Trail Blazer 302 Air Pak
Spectrum 625 Extreme
Suitcase 12RC
Evolution Rage 3 saw
Craftsmen Atlas 12X36 Lathe
Half a ton of tooling
Rusty old truck
Dont worry kill Dozer, I'm not getting pressure and volume mixed up and I dont dispute that the average screw compressor puts out alot more CFM, I only have a 1/2" impact and there are times when I have to wait for my compressor to kick off at 175 to get that little extra to bust the bolt loose, If I'm not mistaken I believe the average screw compressor gives 150 psi max.
Your right about sand blasting, when I have to blast out on a job which is rarely, I have to have both my trucks out on the job and I couple the 2 compressors together.
I have run from 1/2" to 1" impacts off it
And i don't use the blaster very often either but if something needs a massive amount of rust and scale removed you can't beat it even with the mess it makes and metal is real clean even in tight places you can't get a grinder with a wire wheel of any kind and it's way faster...You just wind up having to blow all that abrasive out
It will deliver on high output 31 CFM @ up to 160 PSI @ 100% duty cycle
No tank neededBacked my CATMA over your CARMA
OOP"S clumsy me
Suitcase 12RC
Rusty old truck
Both of my Trail Blazers are down, one in the repair shop and as of yesterday the other one has acted up so I was forced to go buy a new one, I did not get the air pac nor did I go with the EFI.
The price sure has crept up on the little machines however, just under $ 5,000.00
and people think I make to much when I tell them I have a $ 160.00 minimum to come out to a job.
A carpenter typically charges $ 15-20 hr. less than me but $ 5,000.00 will buy every tool he needs and still leave money left to help buy a truck.
A full blown service truck with a crane, compressor, welder and tools is well over $ 100,000.00.
It was a Miller Distributer, The actual price was $ 4463 plus tax that brought it to $ 4730.00.
$ 270.00 shy of $ 5,000.00.
I actual just got a job from the weld supply to do some work on their building so I didd'nt try to talk them down.
It was only $ 140.00 more than what I would have paid online and we have a big job to start on Monday so I was not in a possition to wait.
