Hey Curizer Quick Question???
  • Hey Curizer Quick Question???
    Hey buddy can i hook my 60 series or a 22A feeder to a invertec 350PRO???
    Thx Railmen
    2007 Trailblazer 302G
    2004 Invision 354MP
    1999 60 series feeder
    2005 Maxstar 200DX
    2007 CST280
    1999 HF 251-1
    older Hobart hefty wire feeder
    Hyperthrem 600
    Maxstar 150S(such a cute welder)
    had and sold........
    2003 XMT 304CC/CV
    1947 Lincoln SA200G short hood
    1963 Lincoln SA200G
    1975 Lincoln SA200G(best machine ever had )
    1970's Lincoln SAE400G
    2 Maxstar's 200DX's
    1 Maxstar 200SD
    CST 280
    2 CST 250
    MM130
    Railmen
    Can you swap a duramax for a powerstroke?
      I don't see why not, I hooked my 50 series to my TB, connect up the 14 pin and go.
        Sure can, It only takes money....
        Railmen
        2004 Invision 354MP
        2005 Maxstar 200DX
        2007 CST280
        1999 HF 251-1
        Hyperthrem 600
        2003 XMT 304CC/CV
        1963 Lincoln SA200G
        2 Maxstar's 200DX's
        1 Maxstar 200SD
        CST 280
        2 CST 250
        MM130
        Railmen
          I guess the question should be, does the 350Pro have 24VAC to run Miller feeders.....
          Railmen
          2004 Invision 354MP
          2005 Maxstar 200DX
          2007 CST280
          1999 HF 251-1
          Hyperthrem 600
          2003 XMT 304CC/CV
          1963 Lincoln SA200G
          2 Maxstar's 200DX's
          1 Maxstar 200SD
          CST 280
          2 CST 250
          MM130
          Railmen
            Railmen
            Then you can also make the requested connection. It only takes money.
              I guess...................
              2004 Invision 354MP
              2005 Maxstar 200DX
              2007 CST280
              1999 HF 251-1
              Hyperthrem 600
              2003 XMT 304CC/CV
              1963 Lincoln SA200G
              2 Maxstar's 200DX's
              1 Maxstar 200SD
              CST 280
              2 CST 250
              MM130
              Railmen
                Adaptor cables....
                Thx Railmen
                Start by checking the available adaptor cables in section F-1 in the manual... against the Feeder's cable pinout.. [Lincoln does have adaptors with 14 pin cable that may work)]
                http://www.lincolnelectric.com/asset...oln3/im679.pdf
                  Same Connector??
                  It DOES look like they both use the same Amphenol connector... if so it will be a matter of matching pinouts.. and outputs
                  http://www.heatandweld.com/store/p/4...R-LINCOLN.aspx
                  I would be amazed if the pinouts actually matched each other.. although I am encouraged that the lincoln has pins for both 24vac and 115vac.... anybody know for sure
                  such a thing would be oh too logical and practical....
                    Last I heard,he's vacationing.
                      Ok sounds good
                      2004 Invision 354MP
                      2005 Maxstar 200DX
                      2007 CST280
                      1999 HF 251-1
                      Hyperthrem 600
                      2003 XMT 304CC/CV
                      1963 Lincoln SA200G
                      2 Maxstar's 200DX's
                      1 Maxstar 200SD
                      CST 280
                      2 CST 250
                      MM130
                      Railmen
                        Railmen
                        The V350 Pro has 5.5 amps 24vac available at the 14pin...... the 22 feeder wants 7 amps and the 60(70) wants 10amps....
                        (Note:V350 Pro 24vac circuit fused for 6amps)
                        Miller PSA-2 power adaptor has 7-8 amps 24vac output (depending on literature version)
                        Miller PSA-115/24 power adaptor has 8 amps 24vac output
                        Miller lit says a PSA-2 is ok for an S-74 feeder...
                          Thx Railmen
                          Sure, I do it all the time, generally though I stick a single pole 24 vac relay into the Miller feeder as the lincoln is merely crosses dry contacts "C" & "D", where as the Miller is sending out a 24Vac signal off "B"
                          So:
                          Miller____ Lincoln
                          A _______ N
                          B________ goes to one coil side of the 24 Vac relay
                          G _______ is twinned with one side going to the other coil side of the relay
                          G _______with the other going to "I"
                          C&D go to the normally open contacts of the relay
                          And yes the 14 pin amphenols are the same, however the Lincoln is "Clocked" to "X", ie, the insert is rotated so that the amphenol plug lines up with the "X" on the insert
                            Awesome that is just what I was looking for.....
                            Thx Jeff, you are the man.......
                            Railmen
                            2004 Invision 354MP
                            2005 Maxstar 200DX
                            2007 CST280
                            1999 HF 251-1
                            Hyperthrem 600
                            2003 XMT 304CC/CV
                            1963 Lincoln SA200G
                            2 Maxstar's 200DX's
                            1 Maxstar 200SD
                            CST 280
                            2 CST 250
                            MM130
                            Railmen
