Welding on a diesel alum slip tank?? help?
  • Welding on a diesel alum slip tank?? help?
    I'm a red seal journeyman welder, but have never run into this before. A buddy wants a crack welded on his aluminum diesel slip tank, the crack is on the top, so when the tank moves around it leaks diesel, I was thinking fill the slip tank up almost all the way with diesel and then purge the rest with argon before I tig it up? I know diesel is not as explosive as reg gas, but a few little tips and tricks might go a long way here. Thanks
    I wouldn't take the chance with it full of diesel not to mention the contamination hat could occur. It is discussed here: http://www.thecombineforum.com/forum...el-tank-2.html
      I've heard all kinds of methods for welding tanks but your ultimate goal is your safety. I haven't done one in a while but my method was (is) to fill the tank as full as possible with water. Be aware that some filler pipes extend below the top of the tank so as to prevent complete filling of the tank and leave room for expansion of the fuel. This may demand innovative methods to overcome the air trapped in that space-could be that inert gas purge would work??. DO NOT be fooled by anyone saying diesel fuel is not that flammable--it can be. We have seen a number of seemingly innocuous materials burn or explode including but not limited to motor oil(blew the pan gasket out), liquid fertilizer(burned like gasoline) and molasses(2500 gallon tank blew when we were cutting the end out but it was full of water,resulted in a wet worker but no other damage) All we could figure was that the molasses had fermented into alcohol? I know the whole water thing is a pain in the butt but dead is forever!! I have also heard of welders filling tanks to the top of the filler spout and setting it on fire to burn off any fumes while they weld(see problem with filler extensions above) but it scares the **** out of me. Recognize that just because someone got away with it in the past doesn't mean it is safe. Whatever you do think it though completely before you start,choose a method you are comfortable with and above all BE SAFE!
      good luck.--Meltedmetal
      ---Meltedmetal
        I have repair-welded numerous aluminum diesel fuel tanks with great success. Some were full, some half full, and some empty. Don't get caught up in all the horror stories out there floating around. 99 out of 100 of those stories were because stupid people were doing stupid things. With minimal basic knowledge, and following a couple basic common sense rules, you will be fine.
        First, understand the difference between FLAMMABLE and COMBUSTABLE.
        Second, understand what FLASHPOINT is.
        Third, understand VAPOR PRESSURE and EXPLOSIVE RANGE.
        The diesel fuel that you buy at the pump "no.2" diesel is an NFPA Class-II combustible liquid. It has a closed cup flashpoint of 125 deg. F. It has an AUTOIGNITION Temp. of >489 deg. F. And an LFL AP 0.6% and a UFL AP 7.5%.
        The LFL and UFL have to do with the "sweetspot" of when a vapor is too lean or too rich to ignite.
        I have attached a RUPATABLE link to help clarify the info that I have posted.
        http://www.osha.gov/dte/library/flam...e_liquids.html
        By the way, your idea is the right way to go as long as you are not making really long welds. It is the vapor mixed with oxygen that will ignite, not the liquid.
        JIM
        Owner Operator of JNT Mobile Welding & Repair LLC
        Millermatic 350P Aluma Pro
        Maxstar 150 STL
        Trailblazer 302
        Suitecase 12RC
        Extreme 12VS
        Extreme 8VS
        Spoolmatic 30A
        Miller HF251D-1
        Passport Plus
        Spoolmate 100
        Hypertherm Powermax 45 and 85
        Ingersoll Rand Engine Driven Compressor
        Dake 75 ton H-Frame Press
        JD Squared Model 32 Bender
        Miller Digital Elite
          I have done this many times I will only do a weld job like this two ways one filling tank up with water or a nitrogen purge no exceptions I saw a guy blown thirty feet off a boat luckily he hit the water bounced and rolled into the beach not usually that lucky oh yeah and he totaled the boat
            Thanks for the help
            Thanks for all the help. I think I'll just empty the tank and fill it with water. The little extra time seems like its worth it.
              I have seen a diesel tank bulge and rupture when filled with water and welded. The diesel vaporized that was clinging to the walls of the tank than flash ignited. I'll only weld gas tanks purged with inert gas now. The diesel tank was a write off, blew up like a balloon then split.
              Miller syncrowave 200 runner with coolmate 4
              and wp2025 weldcraft torch
              Miller 125c plasma cutter
                Did you by any chance have that fuel tank capped? If the tank is completely full of water there is no oxygen to fuel an explosion that I can see? However if the tank is completely full and capped the heated water has to have a place to expand into and something has to give. Just a thought. I am not claiming that a water fill is the only possibility but it has worked for me in the past and I am comfortable with it and an inert gas purge of the top air space seems like a really good idea. That said "properly" disposing of a couple hundred gallons of lightly contaminated water in B.C. these days could cause a national incident.(There is just no winning here) If you can prevent the "window"(sweetspot) that jpence refers to(informative link btw) from opening with inert gas it looks like a neater way to go. I haven't used that method so I can not speak to it's efficacy though it may well be fine. I'm a chicken and the idea that if the tank was to pop and splash me with fuel, turning me into the human torch, has kept me from welding on tanks filled with flammable/combustible material. Others are quite comfortable doing this but I'm not. Water also will absorb considerable energy. When our molassses tank blew it shot water up 50 or 60 feet as I recall, all energy moving water and not the guy cutting it although he was wet when the dust settled. Part of the point here is that explosions occur in unlikely places not just fuel tanks and some things have a flammable(explosive) range that you may not readily recognize so be careful and aware not only of what you are working with and on but also what is in the surrounding area cause "Dead Sure" trumps "Sure Dead" every day of the week.
                Meltedmetal
                ---Meltedmetal
                  [QUOTE=jpence38;286605] Don't get caught up in all the horror stories out there floating around. 99 out of 100 of those stories were because stupid people were doing stupid things. With minimal basic knowledge, and following a couple basic common sense rules, you will be fine.
                  Just for the sake of clarity-what you describe are ignorant people, the stupid ones are the ones who do it the second time for no better reason than the first wasn't fatal.
                  Meltedmetal
                  Enjoy the long weekend everyone and take a few minutes to think about the people who gave all that they could to make what we all have possible.MM
                  ---Meltedmetal
                    I weld gas tanks all the time. I use pine-sol floor cleaner and mix it with water and clean the inside of the tank. The pine sol will cut the fumes completely. It realy works I was a little scared at firstbut this really works.
                      I have the same problem. The water treatment plant down the road would go looking if they found a diesel shine floating on the water. Thats why legitimate companies charge so much to fix tanks because of all of the costs getting them ready to weld. I worked for a marania last summer and we did tanks but that said company also cleaned the gasoline barges and had the right equipment and the steam to clean them. Myself i wouldn't do it but i have done them in the past...Bob
                        Originally posted by ganic View Post
                        I weld gas tanks all the time. I use pine-sol floor cleaner and mix it with water and clean the inside of the tank. The pine sol will cut the fumes completely. It realy works I was a little scared at first but this really works.
                        That's a new one for me. All I can say is "Yikes!!" Haha.
                        Good Luck,
                        Meltedmetal
                        ---Meltedmetal
                          I'm kind of in the same boat, if jpence was closer I'd say send him there.
                          Meltedmetal
                          ---Meltedmetal
                            I retired from an oil refinery last year. I was the guy getting piping, tanks, vessels and so forth ready for maintence. I also was the guy signing the paperwork permits (cold work, hot work, confined space) to say without a shadow of a doubt it was ready to weld on and do hot work. I know some contractors thought we were being stupid doing some of the steps because they were in a hurry to get in and get out. But i didn't want to see anyone carried out because i skipped a step. So all i can say is if you feel comfortable on your end just do it. Just remember every tank is different from the last one and it could very well be your last one. Just my thoughts...Bob
                            I met this guy at a refinery and here is some of his story.
                            http://www.americantrainingresources.com/ptv-111.aspx
                              One more thing has occurred to me. If the original crack was caused by a poor weld(it happens in the best of shops) then a simple weld may be a permanent cure. If the crack was caused by the way the tank is being used then some other reinforcement might be in order. Maybe a tight wooden crib complete with tie rods would keep the sides of the tank from billowing. Just a thought.
                              Meltedmetal
                              And Bob I agree 100%-Mm
                              ---Meltedmetal
