AIRGAS high purity Argon (or so they say). The problem I'm having is the last 500 lbs. of the bottled seems to be dirty. Welds don't seem to be a clean and the tip of my tungsten is discolored and kind of hairy looking at the tip. I've had bad gas before but the top half of the bottle seems to be ok. Dynasty 350 DC welding 2% ceriated tung. on stainless and this has happened with more than one bottle.
Gas Question??
Originally posted by corbyndad View PostWhy would the first 1700 psi be good and the rest not?? We cannot switch suppliers as we are under contract.Nothing welded, Nothing gained
Miller Dynasty700DX
3 ea. Miller Dynasty350DX
Miller Dynasty200DX
ThermalArc 400 GTSW
MillerMatic350P
MillerMatic200 with spoolgun
MKCobraMig260
Lincoln SP-170T
Linde UCC305 (sold 2011)
Hypertherm 1250
Hypertherm 800
PlasmaCam CNC cutter
Fadal Toolroom CNC Mill
SiberHegner CNC Mill
2 ea. Bridgeport
LeBlond 15" Lathe
Haberle 18" Cold Saw
Doringer 14" Cold Saw
Originally posted by shovelon View PostYou might want to check your gas flow. As the bottle pressure goes down the output pressure goes up as the regulator tries to compensate. You could be flowing way too much gas and dragging air into the gas stream.
Originally posted by corbyndad View PostThe flow ball is hanging out just under 20. That should be an accurate reading right?I'm using a gas lens and number 6 cup and have good luck til it gets below 500 psi. Bad regulator maybe??
Is there any obstruction on you screen?Nothing welded, Nothing gained
Miller Dynasty700DX
Miller Dynasty200DX
ThermalArc 400 GTSW
MillerMatic350P
MKCobraMig260
Lincoln SP-170T
Hypertherm 1250
Hypertherm 800
2 ea. Bridgeport
LeBlond 15" Lathe
Originally posted by shovelon View PostWell usually the flow gauge is pretty accurate. That is strange. Does the weld clean up if you set at 15cfh? 20 for a #6 seems a bit high to me. I use a #8 at that flow.
Originally posted by corbyndad View PostGas lens is new. Turned down the flow. Same result. Changed bottles and good to go. IDK!!
I guess you should notify Airgas. Yes, my beloved Airgas.Nothing welded, Nothing gained
Miller Dynasty700DX
Miller Dynasty200DX
ThermalArc 400 GTSW
MillerMatic350P
MKCobraMig260
Lincoln SP-170T
Hypertherm 1250
Hypertherm 800
2 ea. Bridgeport
LeBlond 15" Lathe
Originally posted by corbyndad View PostWhy would the first 1700 psi be good and the rest not?? We cannot switch suppliers as we are under contract.Richard
West coast of Florida
Originally posted by Ltbadd View PostWhen did this start? What changed? Certainly this is a new problem? Since you are under contract, it would be in their best interest to help resolve this, IMO. At least try.
Originally posted by corbyndad View PostWe've delt with bad gas from them for years. They are more than willing to replace the bottle with a new one but it gets really old running back and forth from the bottle cage to switch out bottles. We used to run their industrial grade and it was never right we just delt with it and later they switched us to high purity and it was better but now this. They claim we are the only ones in the area having problems. Just a really poor supplier a least here in Kansas.
The first bottle caused me lots of problems untill I switched bottle. The next time I saw this I recognized the problem immediately, returned the bottle to the supplier and insisted they test the remaining gas. They reluctantly agreed but made it right when the test results showed moisture, oxygen, and something else which I cannot remember at this time.
None of these four bottles were tried on stainless.
Griff
Originally posted by griff01 View PostI have encountered 4 (four) bottles that caused problems with under 500 psi left in the bottle. The welds on mild steel all appeared ok but would cause "pepper specks" in aluminum and would not weld thin gauge aluminum at all.
Griff
Moisture?
I'm wondering if moisture is not the culprit. Gasses usually mix pretty well. Any liquid wouldn't. Drop the pressure and the liquid might start to gas (water has a vapor pressure).
Just a thought.Con Fuse!
Miller Dynasty 350
Millermatic 350P
-Spoolmatic 30A
Hypertherm PowerMax 1000G3
