Originally posted by cruizer
View Post
Are there better filters? Yes, absolutely. Do I want to spend that kind of money on them? **** no. I've spent enough as it is with the machine itself and all of the other tools in my garage shop. The plasma cutter itself doesn't need any filters, albeit the consumables will wear out faster without a filter. I figured that the standard Home Depot air compressor/seperator filter is good enough. I've been using the two combined filters now for almost two years. So far, so good. I don't go through consumables hardly at all and I've cut a ton of steel, stainless and aluminum.
....and to the OP, yes a good ground connection is very important. The distance between the ground connection and the actual cut is should always be as short a distance as possible too.
