Powdercoating
Thanks I go look at it...
Powdercoating
Originally posted by Diversion180beads View PostWhere do u get that at??
http://www.homedepot.com/h_d1/N-5yc1...&storeId=10051
To save money on small items, I don't bother with powder coating. I use a spray can of cold steel galvanizing compound, followed up by Rust-o-Leum enamal spray paint. The cold steel galvanizing compound works 10 times better than regular primer coat paint.
If the top coat of paint peals or flakes, I just hit it with some more enamal spray paint. I've been finishing trailer tongues this way now for several years and the finish lasts and lasts. No better or worse than powerder coat, but costs a whole lot less.
we have a setup here that consist of overhead trolley system built by hand. modified old spray booth. w/ 2 hand guns & 1 hopper. ( you can make your own ) & an oven 46' deep, 17' wide, & 12' tall. We coat pipe & parts for fence & make ornamental aluminum gates * custom fence. bake at 400 for 15 to 35 minutes depending on thickness of material. charge is simular to a magnet The powder just grabs hold. you must keep your hooks clean to ensure good ground.
I talked to a guy last week thats spending a few hundred thousand to get started. The true powder coaters also have a wash tank plus a few more to get the parts prepared for the powder. Also the rework is pretty tough if something was missed or damaged. Just my thoughts...Bob
Powdercoating
Wow thats alot of $$$$ but thanks for the info..
The Guy I take my stuff to said it cost him 250,000.00 to get his opperation started he does have a 12 x 30 oven though
Powder coating
I have a cheap set up from HF that cost less than $50 with a coupon and it works great.
I have an old oven in the shop I pre heat the parts after cleaning, then spray them and bake at 400 deg f for 15-20 minutes. I go to my local Powder Coating company and buy powder from then at $10-$20 a pound. It's cheap and it's a lot more versitile than paint. I have a few projects in the welding project site and all have been powder coated in my shop with my little HF set up. So if you are trying to get into it for a small investment for your own projects, I would go this route.
David
Google Sulzer Metco powder coating, that'll give you a rundown on the process.
I'm a tech for them.
Powdercoating
I got a medium sized air compressor but don't do any sand blasting. Like I said I don't know a whole lot about it but just wondering how to go about it. How do get a charge on the paint and on the stell or whatnot??
I was quoted $26,000.00 just for an oven to do my wrought iron work. Then i started to farm out my work to two different coaters and it was pricey and didn't hold up as good as paint on my outside iron. My train bridges inside look just fine...Bob
Diy?
Originally posted by Diversion180beads View PostThanks for the info I'm not real big into steel yet but I knew sordof what it was and knew that it worked alot better on steel than just spray paint but thanks again, have to look into it little more...
One of the secrets to powder coating is that the powder is given a negative (?) charge and the item to be coated a positive (?) charge (It might be the other way around) and the powder is attracted to the metal ensuring complete coverage. If you already have a compressor for sand blasting you can probably get into a small set-up for under $500.00.
