Hi all new on here. With the 350p in pulse mode with AL wire it feed about 6 inches of wire at a slower rate Then it speeds up. What am I doing wrong . Hot start and crater fill are off. Change run in and dose not the wire action. Need help. Thanks
350p
Originally posted by Old Boy View PostGood Morn I use a spoolmatic 30amp. You can hear the motor in gun running slower and you can hear it speed up.Millermatic Passport Plus
Millermatic 350P with Python
XMT 304 /w S-64 feeder and 12VS
Dynasty 300 DX
Thermal Arc 400 MST
Premier Power Welder for my trail junk.
350p
Hi again Thanks I have the run in time at .00. If I adjust the % of run in It seems to makes a difference only at
150. Then at higher feed speeds the arc. will not start if I have the arc. lenght to short. I have played
with this a lot. Was so Mad at this welder. I put a 16 LB sledge hammer beside it. What I did was take it all apart and cleaned and banged very thing I could not take apart. Was not that dirtey as I have owned since new. Now the lights on dash are nice and bright and not flashing dimly as they did before. The best part is I can now control it. Welding real nice. One little problem is that at arc start the wire hits the work so hard the gun jumps back, dose not do this all the time?? ThanksLast edited by Old Boy; 05-04-2012, 06:46 PM.
