The one piece is 3/4", and the stuff I'm welding it to is 5/16", I'm not to bad at welding but have never welded anything this thick. Should i bevel out the sides of the thicker stuff? Should i do more then one pass?I'll be using my miller 251 with a 75/25 gas mix and a .035 wire. Any tips or tricks or any help at all would be greatly appreciated, because i really don't know where to begin.
need some help welding this.
hit_em,
Really not enough info to be of much help. Also the photo was, how do I say, non descript.
With just the info you provided, I'd be more inclined to use a spray transfer mode with a 90%Argon/10%CO2 mix. Considering that your minor material is 5/16", you could most likely do with a single pass. More info about what it is and what the part does would help.
I see a grease fitting in the photo. Grease fittings generally indicate bearings and seals. Will high heat possibly damage the seals?Syncrowave 250 DX Tigrunner
Miller MM 251 w/Q300 & 30A SG
Hobart HH187
Dialarc 250 AC/DC
Hypertherm PM 600 & 1250
Wilton 7"x12" bandsaw
More grinders than hands
