It's kinda like a semi with a 18 spd 550 Cat pulling a 53' trailer with light loads for a couple of years since brand new traveling hills and mountains
Then getting to pull a Super "B" with a max load of flat steel.
It'll take all the gears just to make it up to the top of a hill and the stacks will be pouring the smoke.
However, that same semi, if loaded from day one pulling steel, will be up and over that hill and only drop a couple of gears, with little to no smoke.
Only analogy I can think of cause I've been there....
Same kinda thing with your diesel welder
What is the best way to break in the 350 Pipe Pro with the Mitsubishi engine?
of course the engine is still going to run. the question is is how far away from its best is it running? its going to run if you idle a new engine for 30 hours under no load and glaze it over. it will run if you hold the same load for 30 hours as well. do as the engineers tell you do in your owners manual.
Dam, just use the machine. Seems people here are more a nal about their welders than their personal vehicles, which they put far more hours/miles on eventually. I have several 500 amp plus engine drives, bought used, I have no idea how they were "broken in", but just happily weld away anyway. I can almost guarantee you, no matter how you "break in" the engine, the welder electronics will give you problems before the engine does. Get over it, and start welding.
Thank you for all your device it sounds like putting the machine on the load bank would be the best thing for me to do and yes there's a lot of work in California right now
Cruizer - do you step load the welder or generator or both??
Originally posted by cruizer View PostYep, breakin alot of new engine drives from LWS's and new owners. Step load for a while then hit em with a high load , let em drop to idle and hit them again until I'm happy. Then I change the oil and off they go.
Takes a good 3 to 4 hours
Originally posted by FusionKing View PostSo do you offer a break-in service at your shop?
I was passing thru that way last summer and was as close as Calgary.
Maybe closer. Was coming from Fairbanks.
Originally posted by cruizer View PostEngine manufacturer is not going to hook it up to something and load it. They will start and preprogram it. Its not cost effective for them to load it for several hours, change the oils ect...
Miller installs the engine into the case. Miller really doesn't care if the engine crashes as thats a Engine Warranty thing. Nothing to do with Miller
Originally posted by FusionKing View PostWhy in the world isn't this done already? Looks like it would stop a lot of warranty problems.
high idle will F--k it, best to get alota scrap and go at it with 1/4 " rod, or gouging.
Best bet would be to take it to a repair shop and have them step load it for 3 hrs or so
Originally posted by Paul S View PostWhat is the best way to break in the 350 Pipe Pro with the Mitsubishi engine?
Should I keep it on high idle?
