What is the best way to break in the 350 Pipe Pro with the Mitsubishi engine?
  • What is the best way to break in the 350 Pipe Pro with the Mitsubishi engine?
    Should I keep it on high idle?
    I am assuming that you bought this machine brand new. You will find the recommended run-in procedure in your owners manual. It is typically done with a load bank or resistance grid. you can't just idle the motor, you have to put it under load between 2-4 hours, usually it is what the machine is rated at,(20V).
    JIM
    Owner Operator of JNT Mobile Welding & Repair LLC
    Millermatic 350P Aluma Pro
    Maxstar 150 STL
    Trailblazer 302
    Suitecase 12RC
    Extreme 12VS
    Extreme 8VS
    Spoolmatic 30A
    Miller HF251D-1
    Passport Plus
    Spoolmate 100
    Hypertherm Powermax 45 and 85
    Ingersoll Rand Engine Driven Compressor
    Dake 75 ton H-Frame Press
    JD Squared Model 32 Bender
    Miller Digital Elite
      I'm looking forward to hear how it welds and runs for you Paul.
        high idle will F--k it, best to get alota scrap and go at it with 1/4 " rod, or gouging.
        Best bet would be to take it to a repair shop and have them step load it for 3 hrs or so
          Why in the world isn't this done already? Looks like it would stop a lot of warranty problems.
          Miller 30-A Spoolgun
          Miller WC-115-A
          Miller Spectrum 300
            paul, is there work in cali?
            sigpic2007 dodge 3500 cummins
              Engine manufacturer is not going to hook it up to something and load it. They will start and preprogram it. Its not cost effective for them to load it for several hours, change the oils ect...
              Miller installs the engine into the case. Miller really doesn't care if the engine crashes as thats a Engine Warranty thing. Nothing to do with Miller
                So do you offer a break-in service at your shop?
                Miller WC-115-A
                Miller Spectrum 300
                  Just bring him a cruller and a coffee.
                    I was passing thru that way last summer and was as close as Calgary.
                    Maybe closer. Was coming from Fairbanks.
                    Miller WC-115-A
                    Miller Spectrum 300
                      Yep, breakin alot of new engine drives from LWS's and new owners. Step load for a while then hit em with a high load , let em drop to idle and hit them again until I'm happy. Then I change the oil and off they go.
                      Takes a good 3 to 4 hours
                        Cruizer - do you step load the welder or generator or both??
                        Trailblazer 325 EFI
                        SVI 300i cvcc
                        Mig 4HD & Mig 2E wire feeders
                        Ultra-Pulse 300i Pendant
                        EAS-IV Electronic Arc Starter and Plumbing Box
                        Powermax1000 G3 Series
                        AC-225 Arc Welder
                          Thank you for all your device it sounds like putting the machine on the load bank would be the best thing for me to do and yes there's a lot of work in California right now
                            Dam, just use the machine. Seems people here are more a nal about their welders than their personal vehicles, which they put far more hours/miles on eventually. I have several 500 amp plus engine drives, bought used, I have no idea how they were "broken in", but just happily weld away anyway. I can almost guarantee you, no matter how you "break in" the engine, the welder electronics will give you problems before the engine does. Get over it, and start welding.
                              Drive it like you stole it!
