Hi folks,
I have to weld a few pieces of 1/4" x 4" angle onto existing steel corners on my boat dock (out of water). Plan on stick welding, as outdoors and usually a bit windy there.
First, will I do any damage to the XMT304 or a 6500 generator by using the two together? As I will likely use around 100 amps, I assume that the 304 will be drawing about 1/3 of it's rated full input of about 50amps (220V), so I think that I would only be drawing somewhere between 15 - 20amps from the generator.
I would say the generator should put about nearly 30 amps, so hopefully this is OK. thought I read somewhere that the XMT 304 didn't like to be run off (cheap) generators???
Or, it is about 200 ft to my house and electrical panel. I could run a temporary 2 conductor wire. Using a voltage drop calculator, it looks like i should use a 6 or 8 gauge wire if I were running the 304 on the full power - input of about 50amps. However, as I will likley only be running an input of about 15 - 20 amps, could i get by with a 12/2 wire (have it already) or would I risk damage to the welder? The voltage drop calculator says I would have a 6% voltage drop at 20 amps, 220V, 200ft of 12/2 wire. Is 6% acceptable for a dozen welds which take 20 seconds each, resting to cool down in betweeen?
If I am way off in my numbers, or thought process please let me know.
Any advice would appreciated so I can find a way to do this without buying 200 ft of No 6 wire, for 10 minutes of welding!
Thanks!
Thanks!
