4.5" sanding disc's
  • 4.5" sanding disc's
    guys,
    im having a hard time finding some 4.5" 60 grit sanding disc's WITH the metal 5/8 threaded insert made into it. my old boss got them from somewhere but i cant find them.
    any of you know where i can get them ?
    thanks
    Syncrowave® 200
    Lincoln AC/DC 225/125
    Lincoln Weld Pak 100 wire feed
    4.5" sanding disc's
    Are you saying flap sanding wheels?
      no, just the standard disc, like this, but with the threaded insert in the middle
      http://www.use-enco.com/CGI/INSRIT?P...PARTPG=INLMK32
      Syncrowave® 200
        4.5" sanding disc's
        Sorry, never seen with threads before
          Me neither, only flap discs. Seems that a single disc with an inclusive nut would be cost prohibitive.
          Miller Syncrowave 200
          Homemade Water Cooler
          130XP MIG
          Spectrum 375
          60 year old Logan Lathe
          Select Machine and Tool Mill
            I've used them without the nut and just placed the 5" on my DeWalt using the flange nut I use on my grinding discs. Really surprised how it removes material quick, and leaves a great finish. Bob.
              Acklands-Grainger in Canada has em. They work very well.
              Lincoln Idealarc 250
              Miller Bobcat 250
              Thermal Arc Hefty 2 feeder
              Thermal Dynamics Cutmaster 52
              Torchmate CNC table
                i use the flapper wheels too never used the other kinds . what i do is i use the wheel til it's just about smooth and i save all the old ones .when most of the grit is worn off they make really good polishing wheels. i normally buy the 120 grit wheel from the lws or lowes.
                  There are some at amazon
                  you would also need this
                  http://www.amazon.com/Milwaukee-49-3..._bxgy_hi_img_c
                  http://www.amazon.com/Milwaukee-48-8...313897&sr=1-60
                  http://www.amazon.com/Milwaukee-48-8...313912&sr=1-70
                    thanks guys, im still looking. they had a cheap, thin, sheetmetal type of threaded center insert..... the search continues...
                    thanks again for the help
                    Syncrowave® 200
                      Norton Speed-Change Discs??
                      http://hpmvideo.saint-gobain.com/wsi...ook/index.html
                      can't tell from the Pic but they seem to be what you are looking for
                      Ed Conley
                      MM252
                      MM211
                      Passport Plus w/Spool Gun
                      TA185
                      Miller 125c Plasma 120v
                      O/A set
                      SO 2020 Bender
                      You can call me Bacchus
                        wow, thats what im looking for, exactly.... on top of page 50.
                        thanks so much.... for the help.
                        Syncrowave® 200
