First post here guys! I am welding some aluminum tubing (20ga.) with my Diversion 165 tig. I have the green tungston 3/32" (recommended at the local welding store) Its really welding fine, just very, very short duty cycle. Can't weld more than about 1" and the machine shuts down until it cools. Rarely had this problem with mild steel even when pushing the machine limits. 20 second weld, followed by 5 minutes of waiting. Using straight argon. Anyone have suggestions? This is my first aluminum job and really just want to get through it. Thank you!
165 Diversion issue welding thin wall aluminum tube
Tungsten is wrong first off. You can use green, but it balls up fast.
Buy some 2% Lanthanated and grind to a sharp point. Will give you much better directional arc control.
What are your machine settings?
My guess is that the tungsten is balled up and you're arcing all over the place. 1" of weld in 20 seconds sounds wrong too.
What are you're settings? Are you using a foot pedal?
Originally posted by Drf255 View PostTungsten is wrong first off. You can use green, but it balls up fast.
http://www.millerwelds.com/om/o232895g_mil.pdf
Fig 9-1 on tung selection.... Fig 9-2 on prep
you should not be balling your tung on that machine....
try that........Last edited by H80N; 03-18-2012, 03:36 PM..
Thanks guys. I was playing around today and noticed there may be something wrong with the switch. Sometimes it doesn't shut off and when I set it on the bench it arcs. I noticed the switch is real loose, it doesn't seem to plug in to the connector solidly. I did try some red tungston that I have for steel, but it didn't like that at all. No foot pedal. (next purchase I think). I also think I had the tungston out too far. (Sorry for all the rookie mistakes). Thank you for the advice!
From the manual:
A 2% ceriated tungsten is recommended
At least start with the correct Tungsten suggested in the manual.Ed Conley
MM252
MM211
Passport Plus w/Spool Gun
TA185
Miller 125c Plasma 120v
O/A set
SO 2020 Bender
You can call me Bacchus
