mig welding aluminized exhaust pipe
  • mig welding aluminized exhaust pipe
    "OUR ONLY LIMITATION IS YOUR MIND"
    Yes. Muffler shops do it everyday.
    A little extra prep wouldn't hurt the looks tho.
    Miller 30-A Spoolgun
    Miller WC-115-A
    Miller Spectrum 300
        Originally posted by sickchoppers View Post
        hoe do you know they use aluminized? you ever actually do it?
        I welded alumized for about 8 years when i was working in the sheetmetal shop making ovens for Little Tykes. I made my lathes chip pan from it. No problems welding it. It just sounds different than bare steel...Bob
            I welded galvanized last week...had some galvanized conduit....as you weld it flares up like a sparkler~.....its it like that?...i'd like to use this stuff for custom motorcycle exhaust...when you get into unaluminized it gets expensive
            Nope galvanized burns bright white and flares. Alumized is like welding regular steel just a different noise when welding...Bob
              hi ed roz moving to fla cant wait to finally meet you!
                  I used to work at a shop where we did aluminizing and I used to bring my headers in to aluminize them before installing them. If you want to make an aluminized exhaust for a bike you should build the system and finish grind your welds then aluminize the pipes.
                  We would always sandblast the parts we were going to aluminize first with extra fine blasting media. Prior to blasting we'd wipe them down with acetone to remove any oils from machining and such. We would always preheat the parts a bit before we actually sprayed the aluminum on them.
                  The reason I say aluminize after you weld the pipes up is because you'll burn the aluminum off in the area you weld and will be prone to rusting in the area of the weld.
                  This is a you tube video of aluminizing an exhaust header. http://www.youtube.com/watch?v=gbLHCcCegwQ
                  Used equipment
                  http://www.metalspraysupplies.com/eq...-equipment.htm
                  The one I used is like the spray jet 88.
                  New equipment
                  http://www.imccoating.com/flame-spray-gun.htm
                  I don't know how much aluminizing you could expect to do but if there's no one in your area that does it, it could prove to be a worthwhile investment in the equipment to start doing it as part of your business. I know there are a lot of gearheads in my area who'd love to get their pipes aluminized after welding them up.
                  Miller 340A/BP
                  Victor O/A torches
                  Lincoln SP125
                  Too many other tools to list
                  03 Ram 1500
                  78 GS1000
                  82 GL1100 Interstate
                    yea I did. I leased a muffler shop for a year that was doing a good business already.
                    OEM's used aluminized from the factory before everyone went to stainless.
                    Miller WC-115-A
                    Miller Spectrum 300
                      ahh ok cause welding that galvanized stunk!...thanks so much bob!....jegs is shipping me 5 lengths monday i hope its what i need i' have some custom chopper pipes in mind!
                      Are you painting them, if not I would use stainless and Polish them or use regular steel and Crome them
                      Kevin
                          Are you plating it? Guess you don't know if it is smooth or how it will Polish for plating? Do you have a Crome plater down there?
                          Kevin
                            The exhaust pipe I buy from NAPA is thick enough to use for a driveshaft. Cheaper pipe can be found but it is thin enough to be used for sandwich wrap. Maybe thickness makes for your price difference?
                            Gordie -- "I believe you understand what you think I said, but I'm not sure you realize that what you heard is not what I meant."
