pipe
  • pipe
    What's the on site process while on pipeline?
    Weld-move your truck, weld-move your truck, weld-move your truck, etc, etc...........
    Miller Syncrowave 200
    Homemade Water Cooler
    130XP MIG
    Spectrum 375
    60 year old Logan Lathe
    Select Machine and Tool Mill
      Thank you!!
      Ed Conley
      MM252
      MM211
      Passport Plus w/Spool Gun
      TA185
      Miller 125c Plasma 120v
      O/A set
      SO 2020 Bender
      You can call me Bacchus
        You didn't get any answers so......
        That's a really broad question. There are a ton of procedures used in the differing parts of mainline construction so any accurate answer would be very long.
        But a brief oversimplification would be something like this, downhill (not downhand) stick bead w/5P+ or 6P+ (usually 5/32'), HP, fill & cap w/70+ (3/16") or 8P+ (5mm).
        Puddle cap on pipe up to .500W, 2 or 3 bead cap on heavier wall.
        That covers the majority of pipe gang, firing line and tie-in manual welding.
        Sleeves & TOL's normally would call for a 5P+/6P+ bead/HP and LoHi out.
        The oddball spread will run flux core F/C in the firing line. Or downhill LoHi (LH-D80 or 90 or 100).
        That's not much help, but the predominant skill on mainline construction is 5P+, 6P+, 70+, 8P+ downhill stick. Those skills are basic and money. Others are a major plus.
        This applies to transmission line construction in the United States, other countries are quite different.
        J
          pipe
          That's great haha. I figured the repeat cycle just not all the tech parts. Thanks guys
