all welds in similar size, made with the same filler , and same joint design should be the same, no matter the process used to make it. Filler is rated by tensile strength, so an er70XXX will have 70,000 lb tensile strength
Miller Syncrowave 200
Miller Spectrum 875 Plasma Cutter
Miller Milermatic 135
Ridgid Drill Press
Ridgid Chop Saw
36" Metal Break
Harris Toarches
English Wheel
Ingersoll Rand, 18.1 cfm Compressor
30 gal. Sand Blaster
Planishing Hammer
150lb Anvil
10" Swing Logan Lathe
High is not as high as really high, but really high is a lot lower than REALLY REALLY HIGH. And far is closer than real far, and there is even more distance to REALLY REALLY FAR. But generally speaking the longer thicker welds are stronger than the shorter thinner welds, the ones with deeper penetration and more filler are stronger than the ones with less penetration and less filler. I hope this(and the previous replies) clears up all the confusion the OP had on this topic.
I knew this country boy in the Army. He always used the word "yonder". I asked him one day after hearing this a thousand times, "how far is yonder" .He said "look out there and see as far as you can see" I said oK. He said anything beyond that is yonder. I guess I should have expected that answer.
Nick
Miller 252 Mig
Miller Cricket XL
Millermatic 150 Mig
Miller Syncrowave 200 Tig
2-O/A outfits
Jet Lathe and Mill
Jet 7x12 horz/vert band saw
DeWalt Multi Cutter metal saw
Century 50 Amp Plasma Cutter
Propane Forge
60" X 60" router/plasma table
In my line of work i belive that TIG (GTAW) is the strongest weld form since it is also the cleanest and does not have a true wrong direction, as far as the strongest weld per say i would say any weld that is a full pin (penatration to both sides) would no doubt be the strongest
I would say any weld made for intended purpose and never fails is the strongest verses a weld made for intended purpose and fails before being put into service is the weaker one.I hope this helps :-/
Nick
Miller 252 Mig
Miller Cricket XL
Millermatic 150 Mig
2-O/A outfits
Jet Lathe and Mill
Propane Forge
I can see the moon, is that still less than Yonder? I'm still trying to figure out this "yonder" thing myself. My ole lady uses this word alot. I ask her where something is and she says it's over yonder, I look everywhere I can think of over yonder and still can't find it. I decided to turn the tables on her one day when she asked me where something was that I had no idea where it was. I told her it's over yonder(didn't point or anything), she found it in less than a minute. She seems to know where yonder is but I have no idea where it is, and she can't explain it even though she can find it quickly.
