I just got an old millermatic 35 . I know guys it is a old machine but she did good for about 2 inches and stopped. Pull trigger you can hear it activate but no wire. The wire feed motor is not turning. How can I trouble shoot this welder ? Did I waste my cash on it ?
Millermatic 35
Mm35
Originally posted by orangeboxxfab View PostI just got an old millermatic 35 . I know guys it is a old machine but she did good for about 2 inches and stopped. Pull trigger you can hear it activate but no wire. The wire feed motor is not turning. How can I trouble shoot this welder ? Did I waste my cash on it ?
Flip the wire tension roller up so there's no pressure on the wire, then pull the trigger and see if the motor runs. Another problem may be the tension on the spool spindle may be too tight. A bad diode can cause the drive motor not to run either as it runs on DC current. I had that issue with mine, new diodes that weren't that expensive and up and running again. There's a lot of variables, with the information you've given it's hard to isolate the cause.Blondie (Owner C & S Automotive)
Miller 340A/BP
Victor O/A torches
Lincoln SP125
Too many other tools to list
03 Ram 1500
78 GS1000
82 GL1100 Interstate
