I want to make a bullet trap for .22 rim fire. I see different angles on the strike plate. Anyone have an idea what is the best angle to use. Most I see look to be about 45* but I would think less angle would have less impact. I did a search and it wasn't working well. I looked on ebay and the the more expensive ones had a shallow angle. Anyone with experience here and ideas or pics etc.?
Bullet trap
Bullet trap
Nick
Miller 252 Mig
Miller Cricket XL
Millermatic 150 Mig
Miller Syncrowave 200 Tig
2-O/A outfits
Jet Lathe and Mill
Jet 7x12 horz/vert band saw
DeWalt Multi Cutter metal saw
Century 50 Amp Plasma Cutter
Propane Forge
60" X 60" router/plasma table
and check out some of my ironwork and other stuffTags: None
If this helps, here is a link to pistol range that just opened down the street from me. The photos have captions that say the angle is 30 degrees from vertical and 1/4" thick steel.
Check out the photo.
Miller Dynasty700DX
3 ea. Miller Dynasty350DX
Miller Dynasty200DX
ThermalArc 400 GTSW
MillerMatic350P
MillerMatic200 with spoolgun
MKCobraMig260
Lincoln SP-170T
Linde UCC305 (sold 2011)
Hypertherm 1250
Hypertherm 800
PlasmaCam CNC cutter
Fadal Toolroom CNC Mill
SiberHegner CNC Mill
2 ea. Bridgeport
LeBlond 15" Lathe
Haberle 18" Cold Saw
Doringer 14" Cold Saw
.22LR is really easy to contain. More angle will make the transition less harsh and reduce the chance of debris flying back. It will make your plate last longer too.
Commercial models are made to be cheap. If you have the plate and the time you can make one that'll last considerably longer.
AR500 is your friend. Pock marks in steel really have a tendancy to throw particles back at the shooter so the more gentle an angle you use the better off you'll be. Just one crater from a major caliber can make the material not user friendly.
Shooting glasses are a big gotta have when you shoot at steel. You'll still get an occasional small, hot piece stick you on the neck, or nose, if the range is short.
J
I should add that even tho you mentioned .22LR, if you shoot steel, with jacketed bullets you'll have a large area that seperated jackets minus lead will land in. These can travel quite a way. Velocity is low and so is the risk of real damage but they do tend to fly long distances.Last edited by JTMcC; 02-29-2012, 04:13 PM.Some days you eat the bear. And some days the bear eats you.
Originally posted by aametalmaster View PostI made mine on a 45*...Bob
http://www.millerwelds.com/resources...ht=bullet+trapNothing welded, Nothing gained
Miller Dynasty700DX
Miller Dynasty200DX
ThermalArc 400 GTSW
MillerMatic350P
MKCobraMig260
Lincoln SP-170T
Hypertherm 1250
Hypertherm 800
2 ea. Bridgeport
LeBlond 15" Lathe
