I have been experiencing very low amperage out put with my welder, I had just had 220 service put in my shop so I initially cursed my electrician, but I plugged in my Syncrowave 250 and it worked fine. I checked the plug on the 35 and noticed the ground prong had broken off. I tigged it back on using silicon bronze rod and thought that would do the trick, but no go.
I have it plugged into highest heat range #6, and could just get a decent weld on 1/8" square tubing. The arc has a sizzling sound to it and is kind of erratic kind of like the sound when you run with no gas. Any ideas?
I read in another thread about diodes being shot which I guess it could be, but the OP didn't go into too much description about the weld quality other than he had to crank it up.
Can someone lend guidance on troubleshooting and some "how to" tests in terms that an electrical idiot could understand?
