Ok started a Tig class and were welding carbon steel what the best cutters for trimming up and cutting the rods were going to be using a lot of 1/8 I though a good set of linemans pliers may be a good option
Best Cutters for cutting tig rods
Are you cutting filler rod? I usually use the pre-cut stuff.
A small set of bolt cutters might be good. The compound leverage will make cutting much easier.
For cutting rod material, I usually use a 3" abrasive wheel in an air die grinder. Works well up to 1/2", maybe 3/4" if the wheel isn't worn down too much.
Dynasty200DX w/coolmate1
MM210
MM Vintage
Lincoln AC225
Victor O/A, Smith AW1A
Cutmaster 81
IR 2475N7.5FP
Evolution Rage3
Jancy USA101
9" South Bend
AEAD-200LE
Originally posted by Andy View PostAre you cutting filler rod? I usually use the pre-cut stuff.
Originally posted by Brian Oatway View PostYou use 3/4" Filler Rod.......that's crazy sh!t right there!!!
I pretty much never cut my filler rod. I have cut pieces from a spool of mig wire for small stuff.
I think he said this was 'tig class' so maybe they have a big roll of wire that works as filler, but wasn't really intended to be filler. Probably cheaper that way.
MM210
MM Vintage
Lincoln AC225
Cutmaster 81
IR 2475N7.5FP
Evolution Rage3
Jancy USA101
9" South Bend
AEAD-200LE
All the pipe hands use mostly 9" klein side cutters. Good for 1/8 and under even stainless. Harder wires like inconell will eat out the sides.2- XMT's 350 cc/cv
1- Blue star 185
1- BOBCAT 250
1- TRAILBLAZER 302
1- MILLER DVI
2- PASSPORT PLUS
1- DYNASTY 200 DX
1- DYNASTY 280 DX
1- MAXSTAR 150 STL
1- HF-251 BOX
1- S-74D
1- S-75DXA
2- 12-RC SUITCASES
1- 8-VS SUITCASE
2- 30 A SPOOLGUNS
Originally posted by fabricator View PostAll the pipe hands use mostly 9" klein side cutters. Good for 1/8 and under even stainless. Harder wires like inconel will eat out the sides.
We issued Kleins to students and they survive very well. Cheaper pliers will cost much more in suffering, and replacement pliers!
I use the red handle Klien lineman pliers.Dynasty 200DX "Blue Lightning"
Bernard 3500ss water-cooler
Rockwell vertical mill
Beverly Shear B-3
Beverly Shear JR
Home-made English wheel
Milwaukee Porta-band
" Sawz-all
Tennsmith 36" stomp shear
Powcon 300st
I am having a hard time believing that this question has gotten this many responses. ReallyJIM
Owner Operator of JNT Mobile Welding & Repair LLC
Millermatic 350P Aluma Pro
Maxstar 150 STL
Trailblazer 302
Suitecase 12RC
Extreme 12VS
Extreme 8VS
Spoolmatic 30A
Miller HF251D-1
Passport Plus
Spoolmate 100
Hypertherm Powermax 45 and 85
Ingersoll Rand Engine Driven Compressor
Dake 75 ton H-Frame Press
JD Squared Model 32 Bender
Miller Digital Elite
There is nothing wrong with Channelok, I bought a pair on sale he other day, were not hi leverage but still cut a wire ok. I agree as to lasting, I have a couple pairs of cheap china, they were purchased to ride along but found there way back in to general service, yes, they have been used a lot and were worth the 5 dollars a pair but the cutters cannot handle the continuous use.
I use the same table for stick, MIG, TIG and O/A so most all my welding related tools are on or around there. I do sometimes cut TIG rod if the stock length is too long for me to get it in where I need to use it. So, being on my table, I usually grab my whelpers and just cut the rod to the length I need it. If the rod is too big/thick/tough for the cutter that is part of the whelpers, I usually lay the rod down on the table or accross some other piece of stray stock thick enough to take some abuse and then give the rod a whack to chop it in two with my chipping hammer and that usually cuts it with no problem. Yeah...it may contaminate the rod, but I have never had a problem with that because I use the end that I did not cut for welding. The only big drawback is that my buddies tend to view my method as pretty crude/neanderthal so they all give me a hard time. Oh, yeah...sometimes grabbing the hammer and giving the rod a whack to cut it startles anyone standing there with me because of the CLANG that makes and they then laugh or whine. If they whine I just whack THEM with the hammer!I'd get a pair of KLEINS to keep on the table, too...except that the guys that use my table on occasion are always complaining that I have too much junk on/around there already!!
Reno, NV
Never pick a fight with an old guy. Old guys are too smart to fight and get hurt. They'll just kill you and get it over with.
