Dynasty 300 sequencer won't work any suggestions?
  • Dynasty 300 sequencer won't work any suggestions?
    When I push the sequencer button comes up with help 12 code. Other than that the machine runs just fine.
    Help 12 means you are doing something the machine doesn't like.
    You are trying to set a value that is in conflict with a different setting.
    In otherwords,
    you are trying to set the sequencer when you have the remote set to a standard on/off foot control. Set the remote to a 4T setting and the sequencer will work. It will not work if you are in a manual TIG setting using the remote foot control to control amperage.
    another help 12 would be trying to set AC fequency or balance while you are in the DC weld mode.
    Andy
      Thanks!
