I'm new to weld but I decided to buy a Millermatic 211 Autoset with MVP. I don't know if it is a good machine but everyone was tellingme it is a better brand than Lincoln. The real deal is that I'm want to make a sandblast both and a dedicated gas oven for powder coating. I want the chasis to be made on 1x1 galv. Tube but auto seting the machine to gage16 it turn to melt the tube. Do you guys know any tric to weld this material? Like I said, I'm new to this, but I really want to learn how to.
How to weld on 1x1 galv. square tube with a mig... what's the tric?
Use a push technique.....if u hold the gun in your right hand weld from right to left with your hand/gun laying down to the right about 15 degrees..WEAR aA RESPIRATOR! Grind areas clean if u can and respray with cold galvanizing spray when done..turn the machine down....the push technique and YOUR speed should help with the burn through...Originally posted by Goliad316 View PostI'm new to weld but I decided to buy a Millermatic 211 Autoset with MVP. I don't know if it is a good machine but everyone was tellingme it is a better brand than Lincoln. The real deal is that I'm want to make a sandblast both and a dedicated gas oven for powder coating. I want the chasis to be made on 1x1 galv. Tube but auto seting the machine to gage16 it turn to melt the tube. Do you guys know any tric to weld this material? Like I said, I'm new to this, but I really want to learn how to.
Auto Set
Autoset is designed for mig wire and gas follow the instructions inside the welder door to my knowledge you have to manually set the welder and wear a respirator as early statedNever Satisfied
Millermatic 211
Maxstar 150STL
Metabos
Kennedy Maintenance Pro Full
Makita Cordless 18v Li-Ion
Stihl TS 420
[email protected]
I use to weld galvanized all the time thats right wear a resirator its nasty stuff to weld and as stated when done cold galv spray if you do not grind the galv finish off your weld will be a little nastyEquipment
Lincoln SA 200, Miller 252 , Miller TrailBlazer 275 and Hypertherm Powermax 600
You can weld it
You probably need a lower amperage setting than the auto set is giving. That is one thing I like about my MM135 and MM252 I can dial in exactly what I want. You might need to lower the amps and experiment with the wire speed.
I build tree stands out of EMT conduit and I weld it with fluc core with no problem. If I start burning through I turn the machine down and it ususally stops the burn through.
Wear a half mask NIOSH/MSHA respirator with good cartridges preferably the ones good for most vapors, cause like everyone said the galvinize will make you sick. Also use good ventilation.
After you weld it clean it up good and spray it with some cold galvinize compound like Zinc It.
The 211have auto set but it also can be set manualy, I can set voltage and wire feed but no amps. The machine can work from 30 to 210 output amps or that's what I read on the manual. It said that it produce 90 amps on 120v and 150 on 240v. I'll try to put it on 120v outlet to see if that change something.
Wire speed is ampsOriginally posted by Goliad316 View PostThe 211have auto set but it also can be set manualy, I can set voltage and wire feed but no amps. The machine can work from 30 to 210 output amps or that's wwhat I read on the manual. It said that it produce 90 amps on 120v and 150 on 240v. I'll wire speed is amps...try to put it on 120v outlet to see if that change something.
Thanks a lot for telling me this... Actualy I read about changing the factory ground clamp for one of brass or bronce, is there any diference? I'll set the wire speed extremly low and I'll buy a .030 roll to give it a try too. Thanks a lot to all of you for the tips and tricks!Last edited by Goliad316; 02-28-2012, 07:17 AM.
