I have been told if air plasma is used a nitrate build-up on the cut edge with cause weld problems (brittle,,stress cracks) on the finished part.....I have been told if you grind the weld area on cut part that there would be no problem. Have any of you experience this problem. I just bought a table and will be using a variety of parts for standoffs on pipe, gussets at stress points.. They say oxygen will not cause this problem but the oxygen mix plasmas are expensive....Thanks for your time.
Problems with weldment using air plasma parts???/
This is one of the better explanations of Plasma gas choice. Hope it helps.
http://www.centricut.com/New_Lessons/lessons_9.htmlJIM
Owner Operator of JNT Mobile Welding & Repair LLC
Millermatic 350P Aluma Pro
Maxstar 150 STL
Trailblazer 302
Suitecase 12RC
Extreme 12VS
Extreme 8VS
Spoolmatic 30A
Miller HF251D-1
Passport Plus
Spoolmate 100
Hypertherm Powermax 45 and 85
Ingersoll Rand Engine Driven Compressor
Dake 75 ton H-Frame Press
JD Squared Model 32 Bender
Miller Digital Elite
