What is the correct welder???
  • What is the correct welder???
    Guys I need help to choose a Mig welder that will run 100% duty cycle. The thickness of material to be welded is 6mm lap and T joint. Would you tell me the formula please??
    Thanks,
    Steve.
    Sounds like a machine that will do 150 to 190 A at 100% duty cycle?
      If this is for steel the miller-matic 211 is a great machine. For Al I would uses the 350P with a push pull gun
        You don't get a 100% duty cycle until you get into the bigger industrial units and the smallest 100% job would be the Deltaweld 302. The MM211 is only 35% and the 350P is 60%. What are you welding that you will be sitting behind a mig gun for hours at a time? Most of the time a lower duty cycle will work because you can swap out welded parts, reload the fixtures and so forth and the welder has a time to cool...Bob
          I agree Im not going to sit under a hood nonstop welding, are you hooking up to a robot?
