hobart 135
  • hobart 135
    A guy on craigslist is selling a hobart 135 with regulator and tank for 375 bucks but i talked him down to 300 i was wondering if this is a good buy also how thick of material this welder can handle ?
    Thanks , Ernie
    Great for sheetmetal. The bottle and reg is prob worth 100 bucks...Bob
      Should i go for it?
        Pass on a Handler 135. The Handler 135 has developed a pretty strong history of having control board failure issues. Hobart corrected these issues with the Handler 140.
          I have to jump in. How old is it? What shape is it in? Have you seen it weld? Who owns the bottle? Cmon man, use your head.
          Nick
          Miller 252 Mig
          Miller Cricket XL
          Millermatic 150 Mig
          Miller Syncrowave 200 Tig
          2-O/A outfits
          Jet Lathe and Mill
          Jet 7x12 horz/vert band saw
          DeWalt Multi Cutter metal saw
          Century 50 Amp Plasma Cutter
          Propane Forge
          60" X 60" router/plasma table
            Its 5 years old i and i havent seen it weld
              Ask the seller and have them give you info.
              Nick
              Miller 252 Mig
              Miller Cricket XL
              Millermatic 150 Mig
              2-O/A outfits
              Jet Lathe and Mill
              Propane Forge
                Bob;
                Around here you could Not buy a tank & regulator for $375. , let alone the welder !
                .........Norm
                  im with monte on this one, the bottle can be an issue, they only last so long before they are out dated as far as the 300 bucks, how much more would it cost you to get a new one with a waranty
                    Hey said its in good shape and has only welded about 30 times with it and the tank is customer owned
                      A new Hobart 140 sells for 540 bucks on ebay, is the 140 a good machine?
                        i have one that is fairly old, a few years back i had to mess around with the mechanics of the roller feed, the plastic where it is mounted warped and put every thing out of alignment. why mess with a used welder, i would not spend more than 200 for what he has got, mayby 225 but not much more, ya can get them on sale at tractor supply or home depot and lowes at a fair price. a customer owned bottle is dated, check to see if it is still good
                          I just wouldnt buy it
                            If it works & you want it go buy it. Good price in my opinion. Good for up to 3/16" which is excellent size for auto stuff. If you don't like it you can get your money back by selling it.
                            Where I am a full 80 cf or 125cf customer owned bottle goes for tops $125 used without a regulator when you can find them. I've sold several. New they are close to $200 + fill. Date stamped on bottle is good for 10 yrs. If out of date it is $25 for retest. I've never had a bottle not test.
                            MM250
                            Trailblazer 250g
                            22a feeder
                            Lincoln ac/dc 225
                            MM200 black face
                            Lown 1/8x 36" power roller
                            Arco roto-phase model M
                            Vectrax 7x12 band saw
                            Miller spectrum 875
                            30a spoolgun w/wc-24
                            RCCS-14
