dynasty 350
  • dynasty 350
    Hello,
    Is there a way, to change the gas flow from the separate port on the front of the dynasty to the be in-line with the torch. In other words, for the gas to come thru the dinse connector from inside the machine.
    Thanks
    Originally posted by valenciapoultry View Post
    Hello,
    Thanks
    you certainly could buy the Dinse gas flow thru panel socket and connect it in... but why go to all the trouble??? you would likely void your warranty in the process............
      Do you mean you want to control the gas manually by bypassing the machine?
      I am not sure why you would want that.
      Miller Dynasty700DX
      3 ea. Miller Dynasty350DX
      Miller Dynasty200DX
      ThermalArc 400 GTSW
      MillerMatic350P
      MillerMatic200 with spoolgun
      MKCobraMig260
      Lincoln SP-170T
      Linde UCC305 (sold 2011)
      Hypertherm 1250
      Hypertherm 800
      PlasmaCam CNC cutter
      Fadal Toolroom CNC Mill
      SiberHegner CNC Mill
      2 ea. Bridgeport
      LeBlond 15" Lathe
      Haberle 18" Cold Saw
      Doringer 14" Cold Saw
        Like the second poster said, there are flow through dinse adaptors, however you WILL void the warranty if you still have one. You will also limit the types of tig torches to use.
          If your Dynasty is water cooled then NO.
          The dinse connection for the torch is where the coolant goes through unlike a Syncrowave 200 where the torch is air cooled and uses the dinse flow through design to deliver gas to the torch.
          If your Dynasty 350 is set up as air cooled, then "physically" it's possible. There is plenty of room behind that connector for the Dinse flow though.
          As always, you are assuming all risk with modifications away from the original equipment manufactured.
          Still don't see the need though. The standard air cooled dinse connector supplied with the Dynasty 200 will fit this machine.
          Good luck.
          Andy
