Engine driven welder
  • Engine driven welder
    What would you Welding Gurus recomend for a gas rig to burn 1/4" gouging rod ,
    LWS said Bobcat 250 I read it can only handle 3/16" prove one of us right.
    THANKS
    How much gouging are you wanting to do?
      Gouging
      LOTS OF GOUGING it will be used for welding also but do need gouging from time to time have had the need to gouge maybe 3 linear feet at once 4 times a day.
        Well then IT WON'T BE A BOBCAT WILL IT?, a basic welder to run 1/4" would be a Lincoln sA200 gasser as its capable of putting out 385 amps. A lincoln 305G , 300D, 350D, Vantage 400, Red-D-Arc 3+3, a Miller trailblazer 302, Pro300, or Big 40G/D. There are others of course. But you need big power
          You need something bigger than a 250 amp machine to gouge with 1/4" rods.
          MM250
          Trailblazer 250g
          22a feeder
          Lincoln ac/dc 225
          MM200 black face
          Lown 1/8x 36" power roller
          Arco roto-phase model M
          Vectrax 7x12 band saw
          Miller spectrum 875
          30a spoolgun w/wc-24
          RCCS-14
            A LOT means different things to different people.
              HuHuHu. I may be one of the few that get that.
              JT
                350 amps min.To gouge with 1/4: IMO.
                BB402D
                TB300D
                DIMENSION652
                MM250X
                MAXSTAR140
                HT/PWR-MAX1250 PLASMA
                  I don't know if you'll find a gas job big enough. At the minimum I would go with a 300D. I agree with the 350 amps for 1/4 carbons
                    A 305G will run 1/4" carbons. I burned quite a few with one.
                    Of course, there is always the scarfing tip. Probably the only way to be able to gouge and have a 250 amp machine.
                    Jeff
                      If it was going to be LOTS OF GOUGiNG, I would go with a Airvantage 500 then you could run some decent size carbons.
                      Jeff
                        What elese are you going to be doing with the machine besies gouging I would def buy the biggest machine you could afford. I would recommend the miller pro 300 or 350. If you are going to be doing alot of heavy gouging and can afford the $28,527.00 list price of the lincoln air vantage. But if you are pricing out the bobcat I believe you are on a much tighter budget.
                        Lincoln Vantage Kubota diesel 30 amp spool gun , Hobart 210 with spool gun, Thermal dynamic pak master 75, miller 304xmt all mobile all ready to go.
                          I got a Tb300D and it will gouge with 3/16.I have never tried 1/4" but i think it would struggle.I use my Big Blue 402D usually if i need to air arc.No need to beat the sm machine.JMO.
                          BB402D
                          TB300D
                          DIMENSION652
                          MM250X
                          MAXSTAR140
