i have a miller econotig ce and when i let off the foot pedal the gas continues to flow. there is no adjustment of post flow but its a pre-determined setting at the factory i believe. now i'm no trouble shooter but i removed the gas valve and you can blow thru it. wouldn't it be closed without current to it? - i hooked it back up to the gas without it being on the machine and lo and behold gas comes out. i hooked up my tester @ the terminals and when you apply current i get 24 vac which is what i should have but when you let off the pedal the current is still 24v - shouldn't it go to zero? - the valve appears to be bad but maybe another issue lurking. sorry for the long post-any suggestions?
econotig post flow problem
you guys up north always so rude. its an econotig CE serial #KH488250. the part number is 125785 but has been replaced by miller with a kit number 222837. is that enough or would u like the names of my children and s/s number-geez have a nice day
Originally posted by welder57 View Postyou guys up north always so rude. its an econotig CE serial #KH488250. the part number is 125785 but has been replaced by miller with a kit number 222837. is that enough or would u like the names of my children and s/s number-geez have a nice day
Smart guy that you are maybe this will sink in.... each model name may have several significantly different revisions , and the ONLY way to tell the difference is with the serial number....
Hey guys, I have a GMC that wont shift into 4 wheel drive. Can anyone tell me whats wrong?
Wait, this might help: Its a 1994, Yukon, 4x4, with a 350. Trans is a 4L60E, transfer case is a NP209, vin# GGEETTAAACCCLUUUEEE. Maybe this addition of additional info will help.Last edited by ja baudin; 01-05-2012, 08:43 PM.sigpic
Millermatic 350P
30A Spoolgun
Lincoln Pro Mig 140
Hypertherm Powermax 30
14" Rage Evolution dry saw
40 ton press brake
Evenheat Heat treat oven
1x42 / 4x48 belt grinder
Lets wait and see!!
Cruzier I,m with you.
My2¢
Originally posted by Ronnie View PostWow after that rant what you do to help a member??I know what I would do.
Lets wait and see!!
My2¢
Originally posted by welder57 View Posti have a miller econotig ce and when i let off the foot pedal the gas continues to flow. there is no adjustment of post flow but its a pre-determined setting at the factory i believe. now i'm no trouble shooter but i removed the gas valve and you can blow thru it. wouldn't it be closed without current to it? - i hooked it back up to the gas without it being on the machine and lo and behold gas comes out. i hooked up my tester @ the terminals and when you apply current i get 24 vac which is what i should have but when you let off the pedal the current is still 24v - shouldn't it go to zero? - the valve appears to be bad but maybe another issue lurking. sorry for the long post-any suggestions?
Moral of the story is that according the the operational theory your machine has a non adjustable 15 second post flow. The timer appears to be a linear chip, so there is no way to get around it.
Often if the gas valve is open all the time, the little spring inside it is worn out, dissassemble it and with a little tug on the spring, reassemble it. Other times, something is jamming it open, generally its teflon tape stuck in the orfices.
JeffLast edited by cruizer; 01-06-2012, 09:30 AM.
Originally posted by cruizer View PostIf you did a minor review of my posts (I'm a CST miller tech, and Advanced tech for almost every other brand) you'll notice that I require the serial #. and yes if you want a question answered in a quick format I need that information to pull up the correct machine, correct theory and correct electrical diagram.
Jeff
Welcome..
Welcome to the forum
lots of knowledgable folks here willing to help others with troubleshooting and other technical and welding advice.... the vast majority volunteer their time..... and.... Cruizer is a real gem...he does this for a profession, yet still finds time to volunteer and help out here on the forum.. his patience and knowledge of welder repair is truly an asset here.... Pardon us if we are a bit protective....
