millermatic 250X LB048853 circuit board #196456
i just picked up the welder used. came with the 30a spoolgun for aluminum. when i hooked it up for the first time at my house as soon as i struck an arc with the gun for steel it worked for a second and then cut out. i can hold the trigger down and gas flows but no power to the gun. no wire feed. nothing. i cut the wire and pulled it out. still nothing. jumped the 2 prong plug on the front of the machine for the gun and same problem. circuit breakers are fine. machine turns on just no power to the gun when i pull the trigger. jumpers are hooked up right for the voltage. i have it plugged into a 220 50amp receptical. i tried using the spool gun and that works fine. could the board still be bad?? board looks fine. the machine looks brand new. i dont want to send the board out for repair it thats not the issue. any help greatly appreciated. the machine worked flawlessly before i brought it to my house. coincidence?
