got no arc
  • got no arc
    I got a xmt 304 and bought a used s74dx feeder and everything works great but won't arc. Sure I got it hooked up rite but may be missin something. Any ideas?
    You might have a switch flipped wrong. Any pics of the front of the welder?...Bob
    http://www.millerwelds.com/om/o2208aq_mil.pdf
      Check the connecting cable.
      V readout should be the same between the power supply and feeder, when you've got the selector switch set to remote.
      Have you tried attaching a set of stick leads and doing a little stick welding?
      Syncrowave 250 DX Tigrunner
      Miller MM 251 w/Q300 & 30A SG
      Hobart HH187
      Dialarc 250 AC/DC
      Hypertherm PM 600 & 1250
      Wilton 7"x12" bandsaw
      More grinders than hands
        Did you set the Default Power Source to XMT 304 at start up?
        Do you have the operators manual for the S-74DX to know how to set it up?
        http://www.millerwelds.com/om/o1500_9v_mil.pdf
        Syncrowave 180 SD
        *HF-251D-1
        *WC-1S & Spoolmatic 1
        PakMaster 100XL
        Marquette "Star Jet" 21-110
          I've stick welded and rig welded wih it and have when through the manual and set it all up and still got nothing. It's set on xmt 304
