HI ALL ! i have been welding a little with my 252 and have not heard the fan kick on yet . my question, is it supposed to come on only when it gets hot or is it supposed to come on all the time ? i by no means have been working it very hard short beads at short intervals but i do leave the machine turned on for a few hours at a time .just wandering when is the fan supposed to come on ? thanks CHRIS
MM252 fan not coming on
hey, i have a 252, and you have to do alot of welding, on 24 plus volts to make the fan come on, when im dooing 5/8 aluminum plate, butt weld, i crank her to 27.5 and can go about 6 to 7 feet of continus welding before the fan will cut in, then runs for a quick moment and shuts off. on 24 feet of welding, 5/8 to 1/2 sq butt, aluminum, machine dam near cranked, the fan mote cut in 2 times, and i have never reached duty cycle yet.. belive me, i have pushed it to the point where on a hot day i have seen frost on argon regulator..with it set at 28-30 cfm no lie!, great machine.
Fan is controlled by a thermostat. Only comes on as needed.MM250
Trailblazer 250g
22a feeder
Lincoln ac/dc 225
MM200 black face
Lown 1/8x 36" power roller
Arco roto-phase model M
Vectrax 7x12 band saw
Miller spectrum 875
30a spoolgun w/wc-24
RCCS-14
"Fan-On-Demandâ„¢ cooling system only operates
when needed, reducing power consumption
and contaminants drawn into the machine"
They don't mention it in the manual, only on the sales BrochureEd Conley
MM252
MM211
Passport Plus w/Spool Gun
TA185
Miller 125c Plasma 120v
O/A set
SO 2020 Bender
You can call me Bacchus
