gas lens insulator on a #17 air cooled torch
  • gas lens insulator on a #17 air cooled torch
    hi new poster here
    with a question about attaching a gas lens to my #17 torch
    yes i searched
    i have been lurking for some time and found this forum really helpful
    history--
    I did a course at the Cleveland school of welding back in the 1970,s. and over the years have done some stick, about 5 years ago i got a hobart tig mate and have done some stick ss, mild, and have been doing some alu projects. im using Click image for larger version
ID:	53044125% balanced argon helium, #17 miller torch 3/32 rare earth tungsten or 2% thoriated sharp #7 noz.
    my question-------with pic
    im upgrading to a gas lens 45v26 3/32 and a#7 GL nozzle, and a #54n01 insulator. looking for greater tung extension and better gas coverage. am i right in assuming that the #54N01 insulator is added between the existing one on the torch.? i expected to replace the existing insulator with the #54N01 for the gas lens.
    am i missing something or is this the correct configuration, thanks
    Pull the original white insulator off the torch.
    Miller Dynasty700DX
    3 ea. Miller Dynasty350DX
    Miller Dynasty200DX
    ThermalArc 400 GTSW
    MillerMatic350P
    MillerMatic200 with spoolgun
    MKCobraMig260
    Lincoln SP-170T
    Linde UCC305 (sold 2011)
    Hypertherm 1250
    Hypertherm 800
    PlasmaCam CNC cutter
    Fadal Toolroom CNC Mill
    SiberHegner CNC Mill
    2 ea. Bridgeport
    LeBlond 15" Lathe
    Haberle 18" Cold Saw
    Doringer 14" Cold Saw
      thanks for the reply i tride it both ways and it dont seam right
      take a look
      the original insulator seemed to fit over the torch body. the new one jest sandwiches in not much of a seal.
      torch - original insulator - new insulator. did i get the right cup gasket #54N01
      thanks
      sam
        Mixup 18-7 vs 5401 ??? maybe??
        From the Blue handle... I am guessing this is a Miller Diamondback torch not a standard Weldcraft.... and there may be some variation from standard on the consumables like the shape of the teflon gaskets.... here is the Diamondback lit... it does show it as a 54n01... on the parts breakdown..but....... this may take a call to Miller TIG support or a visit to your LWS.... to clarify interchangeability... sometimes manufacturers "improve" a product without thought to compatability..
        BUT.... is it possible that you somehow got an 18-7 insulator in the place of the 54n01??? 18-7 fits between the torch body and the back cap.... or that you really want a 54n63 long gas lens gasket???
        http://www.millerwelds.com/om/o1600e_mil.pdf
          might be a mixup
          yes its a is diamondback
          the packaging stamped #54N01 but its a wellcraft that might be it. nothing like product standardization.
          im thinking about trying it stacked seems to fit snug like that but im concerned that i will trash the lens if i get oxy contamination.
          give it a shot?
            Originally posted by samhop View Post
            might be a mixup
            give it a shot?
            would not stack them but would check and see how a Diamondback 54n63 long gas lens gasket fits like... a trip to your LWS with the torch might be in order.....for questions and a fitting...
              ya thats probably the thing to do. next time i can get on the boat and get off island i will bring the torch over to the mainland and hit a welding supply store.
              thanks sam
                Island??
                  Island??
                  yup its a boat ride about 1/2 hour at 15 knots. thats why im trying to noodle it out over the interweb
                    lived for a while in coastal NC and the outer banks.. lots of boat and ferry travel there... wherabouts are you??
                      hi new poster here
                      yes i searched
                      history--
                      I did a course at the Cleveland school of welding back in the 1970,s. and over the years have done some stick, about 5 years ago i got a hobart tig mate and have done some stick ss, mild, and have been doing some alu projects. im using [ATTACH=CONFIG]28283[/ATTACH]25% balanced argon helium, #17 miller torch 3/32 rare earth tungsten or 2% thoriated sharp #7 noz.
                      [ATTACH=CONFIG]28282[/ATTACH]
                      I have a few of those on the shelf, they are meant to be used together (both insulators) I made my own out of tefflon stock mainly because I didnt like the looks of them, they worked OK though.
                      I can post a picture if you like.
                      mike sr
                        I think you are right. After a second look it makes sense. I use a stubby gas lenses on my Wp17 which requires the removal of the original insulator. He has the standard gas lense.
                        Miller Dynasty700DX
                        Miller Dynasty200DX
                        ThermalArc 400 GTSW
                        MillerMatic350P
                        MKCobraMig260
                        Lincoln SP-170T
                        Hypertherm 1250
                        Hypertherm 800
                        2 ea. Bridgeport
                        LeBlond 15" Lathe
                          gas lens insulators
                          This is a pic of a wp17 with the homemade insulator and pics of the insulator itself and a standard one.
ID:	512210Click image for larger version
ID:	512211Click image for larger version
ID:	512212Click image for larger version
ID:	512213Click image for larger version
                          mike sr
                            thanks (popspipes)
                            thats what got me it did not look right stacked but i will give it a shot with both.
                            did you make that gasket out of regular Teflon round stock? i should chuck some up and give it a slow tern.
                            H80N
                            jest another wormy Western Atlantic Islander
                              In our shop they are all staked like that... Seems to work just fine. does look goofy though.
                              Linclon power mig 350MP
