just piked up a 251 millermatic-awesome machine. my question is i need a new nozzle but the manual shows 5 different ones. some flush, some recessed, one even called stickout-how do i determine which one i need. the 251 has a miller m-25 gun
millermatic 251
The contact tip flush and contact tip stick out past the end of the nozzle an 1/8" are for short circuit transfer (frying bacon sounding arc). The contact tip recessed an 1/8" nozzle is for spray transfer or a gas shielded fluxcore wire.
For short circuit transfer I prefer the 1/8" stick out nozzle as my general purpose nozzle. The reason being because it allows you to keep a shorter stickout on inside corner joints. I am doing nothing but outside corner joints (short arc), I actually switch to a flush nozzle.
i've got the wire stuck to the tip a few times so i need to watch that a little closer. thanks for the tip- if the nozzles aren't too expensive, i'll purchase the 3 and try them. probably won't run flux-core thru this machine as i have my lincoln set up for that. thanks again
