Hi guys, it looks like I have a welding test coming up for a company. I don't know a lot about their alloys used, just that they're running lincoln push pulls, and and I believe they're running 1/16" solid, probably 5356 since its all specialty structural. Most of my aluminum work has been tig. All I've welded in terms of aluminum wire has been with my own machines, with a max material thickness being welded in the 3/8" range. Anyways, long story short, it looks like they're working with aluminum plate starting in the 3/8" - 1/2" range up to the better part of 1", all from the same gun / wire setup.
1. If you run this stuff on a regular basis, what settings (ballpark) are you running this wire at?
2. If I'm not burning back into the tip do I have to worry about running it too hot on the large plate with a large wirefeed like this? (Too hot = implying a loss of weld strength due to overheating parent material)
3. Most of the stuff there is welded on rotating positioners and clamp tables. If a bit needs to be done out of position, can this larger wire be run overhead and vertical ok? I know I've run .035 and I think some .045 overhead a few years back and it was OK, but that was a lot smaller weld puddle then I'll be dealing with here.
