I am trying to repair crack in cast iron stew pot with Arc welder! Any suggestions?
Ive always save some old glass bead sand blaster media after its worn out. Works great for burying hot material to cool down slowly....
Miller 330 BPA - Sold
Miller 180SD Syncrowave - Sold
Miller Aircrafter 330ST - Sold
Miller 351 Syncrowave - Sold
Miller CP-300
Miller Maxstar 150 STL
Miller Dynasty 200 DX
Miller 135 Millermatic
Miller Spectrum 250D (Now running strong!)
The post above are correct. Please also consider the location of the crack and the exposure of potentially hazardous metals coming in contact with food at elevated temperatures. It might not be worth it.
Welding rods contain no lead, zinc, mercury, cadmium, arsenic, beryllium...
Hazardous? Like nickel? Stainless (18-8)contains 8% nickel. Sure, some people can have a nickel allergy but from coins, jewelry and other contact, not food prep exposure.
Sure, occupational exposure to certain welding fumes/gases/flux can be bad. But use common sense
I'm really mining the crevases of my mind, but, from what I remember of welding cast, and it goes along what has been said.
Grind out, then weld, grind, weld, grind, weld, etc. Due to the porosity of cast it may tend to weep out. Once welded allow to cool very slowly, ie wrap if possible.
