**HELP** Ran out of gas mix on MIG and need FLUX core fast
  • **HELP** Ran out of gas mix on MIG and need FLUX core fast
    I have a Handler 180 and use mix all the time. I need to finish a project and get it done for pickup on Sunday night. I need to convert the Handler 180 to flux core since I can not get gas. Any suggestions? Do I need a different tip and what wires do I need to change inside if it is even an option. Never ran out of gas before and hate to ask such a bad question to all you professionals. Thanks for all help. K.
    Screwdrivers (2) I have one Philips and one straight,
    Hack saw (blade pretty dull)
    hammer (brass, like my [email protected])
    scribe (pretty dull)
    torch (one of those little ones from Ace Hardware)
    wire brush (half worn)
    Beer Fridge (full on Friday, empty on Sunday)
    First, download the Owner's Manual from the dropdown menu on Hobart's site under 'Servce & Support'. The procedure is clearly explained there. Here is the link to the search page over on Hobart.
    http://www.hobartwelders.com/service/owners-manuals/
    Miller DialArc 250
    Lincoln PrecisionTig 275
    Hypertherm 900 plasma cutter
    Jet 14 X 40 lathe...ditto
    Logan 7" shaper
    Ellis 3000 band saw
    Lots of dust bunnies
      Thank you for your help.
        I looked at the operators manual and there is no mention to needing a special nozzle. Does anyone know if this is the case. I read somewhere that there is a special nozzle on another post on another forum. K.
          You don't really need a nozzle with flux core. The special nozzle just protects the end of the gun from splatter...Bob
            I like to leave the exsisting nozzle on mainly to prevent the electrode from touching the work, but its not nessessary.
              Most gasless wires are dc- which means you switch the work/ground lead onto the + terminal & the gun lead onto the - terminal. The wire box should say dc- or dc+. Use the same tip (as long as it is the right size, ex. .035). Use the same nozzle as it protects the tip & diffuser from spatter. If you have any feeding problems try to keep the gun as straight as possible. If you make the rollers to tight it can crush the wire. I think there should be a door chart on the machine for volt & wire feed settings.
              MM250
              Trailblazer 250g
              22a feeder
              Lincoln ac/dc 225
              MM200 black face
              Lown 1/8x 36" power roller
              Arco roto-phase model M
              Vectrax 7x12 band saw
              Miller spectrum 875
              30a spoolgun w/wc-24
              RCCS-14
