Two things I'd like to accomplish on a cast aluminum intake. This is the bottom half of a two-piece intake that I'm working with. The first task is to repair a bolt hole by filling the damaged hole, drilling and tapping. The second task is to remove and block an EGR passage from the intake.
The red arrow points to the damaged bolt hole:
Link to photo
The EGR passage is circled in red:
Link to photo
For the bolt hole, I've seen suggestions to cut a piece of 4043 aluminum round rod, drop it in the hole and TIG weld it in. I have not been able to find 4043 aluminum round rod, any suggestions or alternatives? Also, will I need to have the adjacent flange milled flat after the welding is complete?
For the EGR passage, I plan to remove the passage with a cut off wheel, angle grinder and carbide rotary burr. This will leave an opening in the floor of the intake that is about 1.5" square. The floor of the intake will need TIG welded closed after the passage is removed. Here is the procedure I've come up with from reading the forums:
-Clean the intake manifold very well.
-Grind away surface aluminum where possible (so that new, clean aluminum is exposed).
-Preheat the manifold to 300 degrees (to clean it further).
-Cut some pieces of 4043 aluminum to fill in the hole.
-Use 4043 filler rod.
-Use a pure tungsten electrode.
-Argon shielding gas...?
Does this sound right?
Is it likely that the sealing surfaces of the intake will need to be milled flat after the welding is complete?
I appreciate any advice.
Paul Lohr
Link to photo
Link to photo
Paul Lohr
