I recently purchased an AEAD- 200 le model # 13-118, serial #HG 080830, circuit diagram CB-900 468-1h was laminated to the inside of the cowling.
(actually a Marquete, but the parts are labled aead under the cowling, #'s work in millers site for manuals, etc).
when I bought it, the engine didn't have spark, but the previous owner stated it welded excellent last time it was run. I cleaned the points and it runs great, I'm hoping it is something similar that is wrong with the welder/ generator.
The engine runs strong but no output from any outlets, or welding plugs. When its running I get 1.5 v dc out of the D.C. outlet, I cleaned the collector rings and brushes, checked every rectifier I could find( just continuity( aprox 400 ohm) across terminals, then reverse polarity and the all come up as open), cant find any loose, burnt or corroded wiring and the fuse and circuit breaker all had continuity. The switch (s2) was jumped out on it so both wires#51 and #52 are connected all the time. If I unhook a battery cable while its running it dies.
I was wondering, does the exciter coil need power from some where to make the 125 v dc? or does it create it on its own.
any help or ideas on what to check would be greatly appreciated
