I just bought second hand a MM252and i have about a 25 ft 6/3power cord on my MM35 that i want to change over to the new machine before i sell the 35 i was wandering if it is ok to put that cord on the new machine without any problems? thanks Chris
mm252 how long of power can you add
how long of a power cord can you add to a MM252
Originally posted by ctinberg View PostI just bought second hand a MM252and i have about a 25 ft 6/3power cord on my MM35 that i want to change over to the new machine before i sell the 35 i was wandering if it is ok to put that cord on the new machine without any problems? thanks Chris
Look up Manual to get answer
Copy the Serial Number from the Machine and do a USER MANUAL Search. You should be able to find the answer your looking for. Have a MM200 that had a 50ft. 8/3 SOJW (Rubber Neoprene) cable on it when it was first purchased. Was in a 40'x80' building then; now in a 30'x40' building and welding in one spot most of the time. It now has a 12' 8/3 SDT (Sunlight, Direct Burial, Tray Cable, NO CONDUIT REQUIRED) cable on it. I have #6 to the wall plug from the breaker panel. I still have 44' of that original 50' cable, now its setup as an extension cord, if needed.'77 Miller Bluestar 2E on current service truck
'99 Miller Bobcat 225NT for New Service Truck
'85 Millermatic 200 in Shop
'72 Marquete 295 AC cracker box in Shop
'07 Hypertherm Powermax 1000 G3 Plasma Cutter in Shop
Miller Elite and Digital Elite Hoods
Yes you can put that cord on your MM252.MM250
Trailblazer 250g
22a feeder
Lincoln ac/dc 225
MM200 black face
Lown 1/8x 36" power roller
Arco roto-phase model M
Vectrax 7x12 band saw
Miller spectrum 875
30a spoolgun w/wc-24
RCCS-14
