I have an AEAD-200LE Ser #JH149645 that won't come down off HIGH idle.
I have the Manual and it says that 10 sec's after you stop welding...or shut off the tool you are running using the 115v/100hz outlet, it should kick back down to IDLE.
I bought it fairly cheap but not running. It turned over but wouldn't fire up.
I put all new wires/points/plugs/fresh gas and it fired right up. I haven't tried welding w/ it yet, since the ends on my welding leads are different, but just to try out the AUTOIDLE feature, I plugged an angle grinder into the 115v/100hz outlet and ran it. The welder kicked up to HIGH idle like it was supposed to...but it didn't kick back down to IDLE again after 10 sec, like the Manual said it would.
I have the Miller OWNER'S MANUAL, also the Onan Operator's & Service Manual for this machine, and this is not covered anywhere.
I have it set properly,[using Manual], in WELD position...w/ AUTO IDLE "ON".
I've tried it several times, and let it run for several minutes to make sure it's not just delayed w/ age. I've re-read the Manual. It never kicks back down.
It kicks back down to IDLE as soon as I throw the switch from WELD to POWER tho. Also - when I then click the switch back to WELD, it stays at IDLE...till I hit the trigger on the angle grinder again.
So - my question[s] to you folks is: First- is this dangerous, obviously,... but next, How do I fix it?
Thanks.
Thanks.
